I have a 1989 R32 GTR, with mainly stock HP and stock engine with stock 5 speed manual. My AWD is not working atm so its only RWD. I have a short throw shifter, but the transmission gets extremely hot. I did some reading and found that this is "normal". I'm just wondering, there is no way that these cars came from the factory and it was normal for the transmission to get really hot and transfer the heat to the gear shifter, to the center console trim panels and radiate heat on my legs...
Pretty sure it is "normal". Not shoe meltingly warm but there is a noticeable warmth from the transmission and exhaust, particularly on the passenger side in these cars. Our stagea is the same
On long runs on hot days, without internal sound deadener, it has been shoe meltingly hot in the race car on the nav side
Between the big exhaust and gearbox the trans tunnel in my car gets very warm, nice on  winters day but not so much in summer.
I lined the trans tunnel with stick on reflective heat shield, mostly at the top with a bit down each side.
Huge improvement !
I know this doesn't fix your "hot box" problem but if you consider the temp normal, it fixes your experience.
This is in my Cefiro but its the same trans tunnel as a 32R.
I have found the embosed aluminium sheet works great
The trick with thermal protection is to use a air gap between the heat source, the sheilding and body
Without a air gap alot of heat will still transfer across
Fabricating this stuff is childs play, just start with templates, measure once.....pay twice.....or something like that
Carbuilders brand in pretty good, but, the stuff supercheap sell is basically the same so shop around
https://www.carbuilders.com.au/underbody/heat-shields/
  • Like 1
On 11/10/2022 at 9:46 AM, GTSBoy said:
Would you be so kind as to shoot these surfaces with an infra-red pyrometer so we can understand how hot hot is?
Good idea, i will get a infrared thermometer and let you know. All i know is that it is hot to the touch, like uncomftorably hot. I have a garage door opener that i put in the cigarette ash tray and when i go open the garage with it, it was like it was boiling in hot water
I had the carpet out of the footwell in the stagea yesterday, some aftermarket wires ran across the passenger floor and they had melted into the sound deadener/tar over the years....
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
