I'm about to change my clutch and came across this upgraded clutch fork kit:
https://conceptzperformance.com/czp-upgraded-heavy-duty-clutch-fork-kit-nissan-skyline-89-92-gt-r-95-98-gts-t-r33-30531-cd000-build_p_14924.php
Would that be something to consider while the clutch is out or waste of $$?
Thanks
https://www.sau.com.au/forums/topic/484220-upgraded-clutch-fork-kit-any-good/
The standard pivot points have been known to snap with a combination of heavy clutch and heavy foot, and it is a quick/easy thing to change if the gearbox is off (and a real pain if not)
No idea whether this one is actually stronger than factory, and I've never heard of anyone having a fork issue.
No, it's a very good idea. I run one in the blue R32, I sourced mine from Kudos Motorsports a few years ago.
http://www.kudosmotorsports.com/catalog/heavy-duty-clutch-release-fork-suit-nissan-300zx-skyline-081989-021993-gts25-p-2123.html
In a nutshell it is a factory Nissan 350Z CD009 cast alloy push release fork and boot with a shorter custom height Chromoly pivot ball specific to suit the RB box. The cast alloy release fork is dimensionally very similar to an R33 GTR pull release fork which are heaps more rigid than a stock push. The pivot ball being shorter also decreases the likelihood of snapping and seem far beefier than a stock or Nismo unit.
I've never seen a standard release fork break, but what I have noticed is they a soft as shit and flex a lot. They tend to bend out of spec very easily and wear quite a lot on the release bearing carrier finger area, which causes travel inconsistencies and decreases how much clutch release travel movement you get. If you compared a brand new stock push release fork to a well used one, which I have, you'll notice how flogged out they get after lots of use with heavy pressure plate clutches.
  • Like 1
@BK
Thanks for the input, it's not a lot of $$$ and my only concern was that the throw at the release bearing end would be different compared to the OEM setup.
I think they used the shortened pivot ball to get the travel right.
This is for an R33GTST .. and after 25 years a refresh wouldn't hurt.
It's not the travel distance per se, it's the pivot point angle of the release fork as it is not correct to try and change the travel with the pivot height. Factory fork is around 4mm thick and the cast around 15mm so of course you need to reduce the pivot height. The angle of the release bearing face vs the slave cylinder push rod needs to be brought back into the factory plane. If you use a longer than required pivot ball the release bearing fingers on the fork are not flat on the bearing carrier, which causes other sorts of dramas like side load on the release pivot and chewing out the bearing carrier fork release face.
As mentioned these are good when running high clamp load pressure plates with a substantial increase over the factory 600 -700kg clamp, but will offer little to no benefit if not. I would consider high clamp to be at or in excess of double the factory clamp load, so think NPC 1650kg singles or the Jim Berry full monty which can be 1800 - 2500kg ! Big capacity singles are always the worst offenders as their clamp load is increased far beyond what a multiplate clutch requires.
I run multiplate ATS twin/triples with 1350kg clamp so not stupid high, but still heavier than most Jap clutches like Nismo or OS giken as their clamp loads are generally only in the 1000 - 1100kg region.
  • 4 months later...
8 hours ago, FiXtUrE said:
Sounds pretty fancy in description, but for 65 bux I doubt it’s better than Oem.
The fork is oem - a 350z oem. If it wasn't better Nissan wouldn't have changed it would they...
  • Like 1
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
