hey guys, very long term lurker here. I always use the search function for most things but im stumped here.
I got a built hks rb28 car from japan, it came with documentation of the build and dyno numbers, car should make around 600awhp. Ever since i received the car i hadnt floored it since it was tuned on japan fuel so i ordered a haltech 2500 and went for a tune locally. On the dyno we found that it was dropping fuel pressure from 4.1(idling pressure is at around 4 bar, i know that idle fuel pressure should be 3 bar this is another tell tale that somethings wrong ) to all the way leaning out so the tuner called it quits and told me i should probably replace my fuel pump. I ordered a bosch 044 with a new sock filter, 1050cc injectors, higher flowing fuel filter and a 30 amp relay for the fuel pump we also changed the fuel regulator to an AEM one.. went on the dyno and same exact problem occured except the tuner said its a little bit better. this time, he sent me off with a 6000rpm red line so i dont get into leaning out territory and keeping the car drivable. Here is what the car is doing on the fuel pressure with higher rpms. https://imgur.com/a/qjr8yuY the mechanic and tuner don't really know what the problem is and they are recommending to change all the fuel lines to new braided lines so everything is fresh or performing a fuel pressure test, i've spent close to 4k chasing this problem and im kinda burnt out.
Could this be a leaking vent hose, either on the fuel tank or the charcoal cannister? maybe a bad fuel damper? replacing the fuel pump to a stronger one than before made car lean out a bit later in the rpms but still is running way too rich to lean, what could this mean? Any leads would help!
thanks
Edited by damnonrs
https://www.sau.com.au/forums/topic/484256-frustrating-fuel-pressure-issue/
2 minutes ago, robbo_rb180 said:
A single Bosch 040 isn't big enough........
Go to a modern drop in TI or bosch probaly 2x 460lph with a new or modded hanger and stage the 2nd pump at like 3500rpm and 50% TPS
im using a bosch 044 which is good enough for 600ps. but bosch 040 you said is also good for 700hp. my car leans out at 450hp on the dyno, i dont think this is a fuel supply issue, i think im chasing a vaccum or fuel pressure problem.
Did you recently purchase that Bosch 044? That fuel pump was released about 30 years ago and has been discontinued by Bosch... Even if it isn't a fake, there is no reason to use this pump over a modern fuel pump.
If a pump is advertised as "supporting 600HP" that does not guarantee that it will indeed support 600HP on your build. Also, certainly the HP rating of the pump is at the motor and not at the wheels.
There is a huge difference in the fuel pump requirement between a big NA V8 on pump 98 making 600HP and a small 4 cylinder turbo on e85 running 40+psi boost making 600HP.
In the defence of your 044, maybe it's 28 years old and has finally worn out lol. In any case replace the pump with something modern. I'd recommend starting with a Walbro 525 and going from there. You can always throw in a twin hanger and get a second one if need be later down the track.
For $200 you can replace your dinosaur fuel pump and most likely resolve your issue. I don't understand why you are reluctant to do so.
  • Like 1
same thing ones internal one is external.
its 600hp is generous and at 4 bar of pressure and drops off shows its not big enough but hey what would I know..............
My tuner put me on this fuel pump which actually made the flow a bit better than my previous pump. I attached a picture of what the car was doing in japan with a less flow fuel pump, we put it on a dyno here and it couldn’t even break 400hp with the fuel pump the car came with. Fuel pressure is all wacky and fluctuates. Also they made a new 044 pump
7 minutes ago, damnonrs said:
I also want to mention that the car gets about 150km on a full tank with normal driving and just spews fire non stop
Post your ESP map.
Log every channel and go for a drive. Post your data log.
Just a FYI. The 044 is indeed gone mate.
https://www.bosch-motorsport-shop.com.au/blog/tech-product-overviews/the-044-is-dead-long-live-the-bosch-motorsport-200/#:~:text=After 28 years of setting,number%3A 0 580 254 044.
Another vote for the "044 is too small". It is too small. We all learned 20 years ago that you would need more than one such pump to support the sort of power you're wanting.
As to your fuel consumption issue......that's most likely to be a tune thing. Do as advised above.
  • Like 1
47 minutes ago, Dose Pipe Sutututu said:
Sounds like you need a new tuner, the fuel pump recommendation is one indicator that he/she may not be up to date with mainstream modern/proven products.
yea i kinda agree, hes smart and the car came with this problem from japan so it was the logical thing to go to a new fuel pump. but i agree maybe 044 wasnt the best choice. anyways the fuel pump is not the problem here, its a fuel pressure issue where it idles too high fuel pressure and drops under load.
I have attached some data logging. this was from the last time i drove the car, car is put to storage while im trying to figure out this problem. i think fuel pressure logging wasnt turned on by the tuner but i have attached a video of what the fuel pressure does under boost. https://imgur.com/a/qjr8yuY
I inspected every single line in the front and underneith. what im thinking is maybe a vaccum line or a vent line ontop of the fuel tank is broken and it cant build pressure under boost in the fuel tank.
2022-12-06_0528pm_Logs323to386.csv
Not sure if the GT-Rs use them, but is there anything between the fuel pump and fuel tank lid/cover? On the S15s (no idea why) there's an over pressure valve that dumps fuel back into the tank when fuel pressure goes above 4 ish bar.
Looks like this:
Looks like this:
from the googling i did, i dont see anything like that. i also just tried priming the pump. it primes to 4.11bar and then drops to 1.1, are the pumps supposed to hold the pressure at around where it primes to? I also tried without the gas cap and it acts the same way as with it screwed on.
Does the car have an adjustable fuel regulator? If it does lower the pressure.
The way a fuel regulator works on these is there's a set base pressure (usually 3bar or just under with vac reference removed) and as manifold pressure increases so does fuel pressure.
It still a fuel pump issue. As has been stated. Your American yeah? I'd listen to the Australian guys who have more than 30years of experience with this platform.
when the factory regs failed I've had low pressure not high.
@Dose Pipe SutututuI still think we should go over there and show them how to set these things up properly and tune more than just full throttle cells.
  • Like 1
I'm in canada lol
can you explain how the car as is in japan 4 years ago with a lesser flowing fuel pump than whats in there now was making 550rwhp and i can't get past 400 with the same exact setup except 4 years later. the car had been sitting for a bit. i dont know how else to explain its not a fuel pump issue unless the pickup is leaking.
I understand how a fuel regulator works and buying a new regulator and playing with it could damage my engine. its the stock regulator on there which is good for heaps of power, the car has been tuned around this problem (which is no good i understand) i am trying to solve it and put it back on a dyno asap.
Edited by damnonrs
I'm in canada lol
It's very easy to explain, you can make a dyno show whatever power figure you want very easily. For all we know the car never really made a genuine 550rwhp, it's just what the dyno printout showed.
I don't know why you are so focused on the past and what the car supposedly did in Japan.
Why not just focus on the issues you have now and resolving those.
  • Like 3
So you are telling me a reputable shop built and documented a 2.8 build by hand and gave the car to the customer that goes through a fuel tank in 100km and ran his car on the dyno leaning out and he drove it for 4-5 years like this?
anyways I’m focused on the present. What would your next step be knowing all this?
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
