Hi there, I'll get right to the chase.
Put a set of aftermarket seats in my 98' R34 GTT 2 Door, and obviously have had the airbag light come on. Just wondering what the quick fix is. I'm happy to buy the right resistor online as opposed to making one and cutting into the wire myself. When I installed the aftermarket sterring wheel, the boss kit came with a resistor which worked perfectly, should I look at using the same sorta thing or will the seats needs a different ohm resistor?
Apologies if this has already been answered but I'd rather just buy the right part and be done with it.
Thanks in advance!
https://www.sau.com.au/forums/topic/484381-er34-seat-airbag-light-fix/
What are yall on about? Unless I'm blind, there is one airbag in each seat. SRS logo on the side, yellow connector plug underneath that wires directly to the airbag control module in the very centre of the car. Plus I even have the original sales brochure from Japan and it has seat airbags as an option.
Please enlighten me if I'm wrong.
  • Like 1
The airbag light isn’t a direct globe, it’s apart of the circuit board of the cluster. I’ve had it apart to pull the HICAS light and thought it would be the same, but it’s not. For obvious reason you can’t tamper with it.
This is the first I've heard of it :D. Do you have any more photos of these R34 seats that have airbags in them? It must have been a very very rare option for people to select for some reason.
My solution is leave the OG seats in. Unless you have a 5/6poiny harness, HANS device, cage and are on a racetrack, I much prefer an airbag that is functional. You're at the point where people do 'foamectomies' to seats to make them fit better as opposed to just removing certain elements of airbag functionality.
Some cars have an option from the factory where you can actually reconfigure which options the car has (I did this with a Megane to tell it it didn't have TPM's from the factory). No idea if the R34 or any skyline has any functionality of sorts for this.
4 hours ago, Murray_Calavera said:
Don't know if it bothers you or not, but as soon as you remove an air bag the car is no longer street legal.
Yeah that’s not a problem for me.
Aftermarket seats will be staying in the car. I can get more photos but it’s not that rare, two close mates of mine both have very standard GTTs and both also have seat airbags.
In that case, your options look to be;
  1. Measure the resistance of the airbag connection on the seat you took out. That's the value resistor to connect to the loom plug. Bonus points for setting off the airbag with the multimeter's battery.
  2. Just a resistor substitution box onto it, set to some value maybe half what you used on the steering wheel. Gradually increase the value on the substitution box until you stop getting the light. That's the value resistor to connect.
  3. American fix. A black sticker over the light on the dashboard.
    Well, that's not strictly true. If it's an LED on the PCB, you've already missed your opportunity to "pull" the globe by just desoldering the LED from the PCB. Would have taken 2s plus warmup time.
Looks like this will be the case.
I know full well I could desolder it from the board, however it’s a Nismo ER34 Manual cluster and they’re worth a small fortune. So I chose wisely to not to.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
    • What ECU are you running? This is probably the biggest question. If it's a PowerFC, I'd probably change the ECU and get something newer that will handle the injectors in a nicer way.
