Hey guys, I have a 2020 Kia Stinger GT fitted with a Stingerhaus Body kit and Rear race type wing, I’m in the body repair trade and was pulled over by cops and was given a defect notice for the rear wing and front wings on bar and front guards.
asked the cop why it was illegal and he could not specify why exactly except saying it could injure a pedestrian ?
anyone know the laws around these? B56E9A9B-26F6-4371-A995-B80AFC282404.thumb.jpeg.73bb6cf51945afaf556eecb561a626e2.jpeg
https://www.sau.com.au/forums/topic/484531-rear-wings-legal-or-not/
Generally....
Side skirts and front and rear spoilers may be fitted without specific approval, provided road clearance and air flow for brake cooling are not adversely affected.
Additionally, they must not be fitted so they are likely to increase the risk of bodily injury to a vulnerable road user coming into contact with the vehicle. All material is to be of a suitable thickness and be free from sharp edges or corners.
Rear spoilers must be within the body shape/outline of the mounting surface, for example, the boot outline. The minimum thickness of end plates is 4mm and they must be free of sharp edges or corners.
Having said that, I'm only familiar with NSW and QLD legislation/regulations, VIC might be different.
5 minutes ago, Murray_Calavera said:
Generally....
Cheers mate. 👌
The rear wing endplates and stands don't meet the requirements as above - They need to me smooth and not sharp.
image.thumb.png.fd299774c8adcb2efede4e9f7ce7b2e0.pngimage.thumb.png.06acea3990e4ed5df1afd50924be4249.pngimage.thumb.png.8c78b125466369b97107a21d41eaa3f2.png
There's some examples of legal wings. You'll note that every OEM wing follows this kind of design principle.
This is a subject that pi55es me off; tank-life 4wds can be fitted with steel and aluminium literal battering rams on the front, winches, spotlights, steel bike racks on cars etc and apparently it's fine. Yet you get told those front wings are 'illegal' and hazardous when they appear to be constructed of a suitable material, no sharp edges or corners, don't protrude more than 150mm from the body outline, etc. The section of the Code which covers this is so vague and brief, and open to interpretation for the most part that it comes down to the individual's point of view.
Eg " All material is to be of a suitable thickness " suitable for what? Thick enough not to constitute a sharp knife-like edge, or not too thick that it still creates a breakable/collapsible structure in the event of collision? Depends on the specific part of course so, open to interpretation.
Looks like your wing endplates all have rounded corners rather than sharp points; are the end plates more than 4mm thick?
  • Like 1
Not to mention ladder racks and trailer steel mudguards.  I have a rear wing, haven't been accosted by the law yet but its always there!!!  I think the reasons and the 'law' is an ass on this...they should be focusing on real lawbreakers rather than displaying their awesome power by nitpicking.
  • Like 1
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
