Hello all,
Me again with more brake questions, lol.
I have a r33 GTS-T. The calipers are GT-R Brembos, but the previous owner put oversized rotors on (14in/355mm front and 13.5in/343mm rear). I'm not sure where he sourced these rotors, but I have been unable to find replacements of the same size.
The EBC rotors I purchased designed to fit the r33 GT-R are 12.8in/324mm front and 11.8/300mm. They also sold GTS-T rotors which are 11.6in/296mm front and 11.5in/295mm rear.
I'm not really sure how to approach this. Right now. My Brembo calipers are too far away from center to use my purchased rotors. Can I remove the Brembo mounting bracket adapter and bolt the calipers directly onto OEM mount? Can I purchase new mounting bracket adapters to fit my smaller rotors? Or do I just need to source larger rotors?
I appreciate any advice.
Thank you.
Edited by IXMandalorianXI
Hello again!
Have you brought the rotors into a brake supply store in person? I would expect that the current rotors could be matched up pretty quickly if the staff at the store were able to play with them in person.
Just now, Murray_Calavera said:
Hello again!
I called EBC and they didnt think they had anything but they might have been trying to match the car, not the combination situation I have. I didn't think of trying to go in person. That might be the optimal solution.
Once they match up the rotors for you, just make a note of what car they come standard on to make life easier in future.
Was on the phone with EBC and looks like the Nissan 370Z has 355mm fronts and 350mm rears. And is compatible with the r33.This MIGHT be it, and I'm going to re-measure my rears and see if this solves the problem.
2 minutes ago, ACTIVE-LSD said:
Yeah those rotor sizes are uncommon. I wonder if they were purchased from HFM Parts?? they are the only company that i know of that do irregular rotor sizes. They do R33 GTR 354mm front & 340mm rear.
Oh, thank you for the information. I will check that out.
Take a photo, if you're using dogbone/adaptors it might give us a better understanding.
370Z calipers are actually Akebono.
Should have time tomorrow to lift her up and take photos of everything. Would different calipers require different discs? I know for certain I have Brembos on the r33 GTS-T.
Yes different calipers require different discs as the offset would be different.
Snap up a photo, I'm sure all of us can try work out what you have
Easiest way out is probably to ditch the adapters and bolt the brembos straight in the stock location, then use factory R33/R34 GTR discs. They will be sufficient for anything except serious track use
*edit*
sorry let me clarify that. You need to know if you have R chassis brembos (what I assumed above) or Z chassis bremobs because they require different disc offsets. If your ones are Z chassis brembos your caliper adapter should just allow you to run standard size and offset z chassis discs.
Bit hard to guess this on the internet. DBA.com.au have a very good catalogue which will allow you to measure and identify the discs you have.
Ok, so several updates
I remeasured both the front and rear rotors:
  • Front: 355mm x 32mm
  • Rear 350mm x 20mm
Which reflects the 370Z exactly.
Next, as requested, pictures:
FRONT BRAKES:
REAR BRAKES:
Make sure you measure the hat height/offset too.
Looks like someone has manufactured dog bones to suit, haven't seen such kit before!
So, some exciting updates.
1.) EBC has been super helpful and is exchanging my rotors for properly sized ones
2.) On the way to work today, my brakes seized up and would not to fully unclamp from my rotors, causing them to become red hot.
3.) I took it to my mechanic and he thinks my ABS might have gone bad, among a number of other things. So I decide to nuke this problem and am having him completely rebuild my brakes with a new master cylinder, ABS block and caliper pistons. And just because I'm officially sick of dealing with these brakes, I'm going to have him put the new rotors and pads and and bleed it the damn thing for me, lol. For the price he offered and the quality of work he does, I can't complain.
I really appreciate everyone's information and help, thank you. I learned a lot through this little adventure!
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
