Hi all,
I just purchased a '98 Stagea Autech 260RS. Based on my research, it's #412 of 1784 across both series. It has 142k km and is mostly stock, save some GT-R R34 rims and a Tomei(?) front grill. I'm based in the States, so this car was never sold here in any form. We didn't get the GT-R here until the R35, so the drivetrain is an unicorn (ironically). I'll be picking up the car in a couple weeks and driving it cross country to its new home. For now, I'm scouring the internet and educating myself on the care and feeding of these beasts. So far, I've determined that I can't just look up parts anywhere in the US, so starting to amass a list of cross-referenced parts. Anyway, I'm excited that there's an active forum for these cars and their sisters. I plan on gleaning all sorts of information from you.
Hi. I'm Kip. I've bought a car that doesn't exist where I live. I'm a fool.
-Kip
  • Like 1
https://www.sau.com.au/forums/topic/485025-fool-in-the-states/
5 hours ago, Kip said:
Hi all,
-Kip
It's not that hard. Many parts are sold direct through Nissan USA dealers now, just look up the part numbers through the parts catalog. The 260RS is entirely R33 GTR as far as drivetrain goes.
Welcome Kip.
You'll be fine. I have a car (well, "truck") that not only does not exist where I live, but I had to have  converted from LHD to RHD as well.
Both drivetrain and engine are generally R33 GTR, but you can get info here on specific differences
  • Thanks 1
On 10/26/2023 at 4:44 PM, soviet_merlin said:
:wave:
From one fool to another, I'm sure you'll be fine. Do you have any photos of the car?
Here are a couple of the "glamor shots" from the dealer. It's pretty much stock (as mentioned above), but does have a set of meister coilovers and a modified exhaust. The interior is untouched which is nice. Tires are on order to add a little more sidewall and I'll adjust the coilovers to put the wheel wells just above the tire instead of down on the rim.
  • Like 4
I didn't know Nissan USA would help me out. Very cool. That's half the battle (the first being tracking to the right part numbers).
Yeah. Reading a lot about the R33, since mine is essentially the wagon/estate/combi/avant model of it. I'm excited to have one of the ultimate sleepers.
  • 4 weeks later...
18 hours ago, soviet_merlin said:
Nice one, looks very clean! I always much prefer the boxy more aggressive look of the S1 over the S2.
Thanks. Just picked it up last week. Drove it 32 hours across the country to its new home and then some more local, holiday travel. Over 4,000 kms in all. The car can really eat up the miles.
And the petrol! It seems the car is more modified than I realized. I think it has an old school tune on it that is dumping too much fuel into the mix, based on the soot collecting on my rear bumper cover and the 13l/100km consumption I'm seeing. Regardless, it's an interesting car. I'm enjoying getting to know it. I'll get it off the ground this week and go on a fact finding mission. See if I can get a better understanding of the mods.
  • Like 1
Oh wow, that's some serious distance! That's an easy half a year worth of driving for many. I'm glad to hear it made it okay.
I wonder if the soot could also be from the exhaust setup. There's a highflow catalyst on mine that does pretty much nothing and smells terrible. I have been blaming the gunk on the bumper on that. Not sure though.
It drove beautifully. It really likes to just cruise around 130-140 kph. The exhaust quiets down. It's off boost. It just eats up the kms. It's almost zen like. 😉
You're right. The exhaust has something to do with it. I believe it's some sort of HKS exhaust, at least from the cat back. It has an ~10cm tailpipe that has both limited clearance of the bumper cover and points upwards a little. It's a cool visual that's a total 90s throwback for me, but it's creating some of the discoloration.
2 hours ago, Watermouse said:
Would a modern aftermarket ecu change that somewhat?
If you ran a wideband and tuned for a lean cruise you could save some. But it's just not an "efficient" engine design. Manufacturers have put a metric shit tone of work into reducing fuel consumption in the 35 years since that engine was born. Port design, chamber design, high compression, valve timing control, injector placement (and quality!), low tension piston rings, thin oils, smaller bearing journals, low drag engine ancillaries, etc etc. None of these modern things have you, hmmm?
It will help a little as others have said but don't expect miracles. And most tuners are not remotely interested in tuning fuel economy so expect to have to learn and do it yourself.
Welcome! You've effectively got an R33 GTR wagon, so most of those parts can come from an R33, which most Nissan spares can order for you in the US these days. Body panels will be hard, but the US has some of the best body work and trim shops if reality TV is anything to go by :D
Sounds like you might have a remapped ECU, pop the carpet out under the passenger side and see if there's any tuning shop labels on the ECU, that's usually the easiest way to tell, or you might have to open up the ECU to see if there's any EEPROMs changed out etc.
    • Nah, they'll do it without a receipt, tell em roughly when it was, that it was cash, youll likely only get store credit, but that gets you some dollars towards the newer better shovel, or other item you need/want later.   Still take it back and have a crack at returning it.
    • Nah. Was just wondering if you were having a small stroke or if there was some slur/gaf/inside joke that I wasn't aware of.
    • That was a fark up, it's Salamanca Place I was thinking of. And now I'm curious as to what potential slur/gaf I have caused with Salamander Road, ha ha!
    • Actually everyone on the roads was really well behaved. The only person that did any minor tailgating was a local hoon in a Turbo Focus. Unfortunately we weren't going the same way so there was no grand initial D touge battle. Lots of people pulled over and let me through. The amount of "Hey man nice car, omg skyline, nice 34 man woo" was suprising. Like really suprising. Like almost annoying. My partner was obviously surprised, she'd never seen anyone in the real world point out the car/like the car/want to chat about the car before, so to have like 3 people per day mention it was notable, I could finally say SEE? SOMEONE THINKS THEY'RE COOL. Everyone was also pretty suprised about the weather. Every day was dry and about ~13-14C. Mount Wellington had a sign that said they close the gates at 9pm and I was heading up there at about ~7:30. It was VERY apparent that conditions were getting significantly worse by the minute on the way up and down. The road on the mountain was terrible though, it's no driving road. I have various suspension related questions now. Luckily it was only about 20 minutes from where we were staying to the top of the mountain as said Google maps. We only had the 2 nights in Hobart. We went to the Farm Gate Market though which was really good - And went down to the Hastings Thermal springs/caves down there during the day. I'd definitely be up for going back again, so luckily there's a few more sights yet to see. Didn't get to do the west coast/queenstown/cradle mountain so this was supposed to be a 'scouting' trip anyway of sorts if I were to one day do/take part in/organize a more car-focused trip. As for the boat, it wasn't bad. Well it was bad, but not in the way you're thinking. We did the night trip which leaves at 6:45 (though you have to be there ~2 hours earlier) and arrives the next morning at about 6am. There is nothing to do on the ship. If you plan accordingly and bring a book/tablet/show to watch/charger you can just chill out, take some Travacalm and just sleep through it. The food there is an extremely basic buffet that costs $32 a plate, or $14 for a $3 pizza. The way back we had a travel kettle and a few different types of cup noodles and made our own tea/coffee in the room. This was a far superior way to do it. At the very least book one of the rooms with beds. I guess as we were in the off season we didn't have room mates. You get an option for rooms with 4 beds (2x bunks) or a room with just the two bottom beds. There's also some option for a deluxe queen bed but it's much pricer. We've been on sleeper trains in Asia before so we figured this is similar (and it was)
