Okay update I have placed an order on the parts. The speed sensor is coming from the USA so it will take some time for it to come over to AUS early FEB some time. But I am also getting some other parts at the same time like a rear main seal (May as well do it while I have to box out)
I will keep the form posted how I go :)
Found this neat website that lists all the details about the 71-Series transmission (RB20DET) speedometer gears and ratios / history. The website also lists what is compatible with what.
http://datsun1200.com/modules/mediawiki/index.php?title=71
Also web archived it for future uses (If needed :) )
https://web.archive.org/web/20240109124810/http://datsun1200.com/modules/mediawiki/index.php?title=71
There's some problems with the "technical editorial" on that page. The author goes on about how the 71C is real strong and handles 3L turbos just fine. And it's just not true. I killed the input shaft bearing on 2 of these behind an RB20DET making only ~170rwkW. They just aren't tough enough to handle that sort of torque for very long. I wouldn't even contemplate it behind a 25DET.
But otherwise, that's a good find.
  • Haha 1
  • 3 weeks later...
Just letting you guys know that the R33 brake pedal has a higher pitch bracket on it so it didn't line up with the R34 auto 5th dash screw.
Ended up drilling a hole in it and putting a thick spacer in between. All seams very tight.
  • Like 1
Couldn't quite see what you mean from your photos, can you share a pic of the drilled hole and spacer? Still promising myself that one day I'll fit all the manual bits I've got in the garage. Is the rusty one the R33 pedal?
I certainly would but it's all in the car now 🥺 the R33 pedal is the rusty one. I was able to figure out where to drill it by putting them side by side from one another and used some rulers. As the R33 pedal was a higher pitch and longer I used a thick 2CM high pipe (was going to use a couple of nuts) to fill the gap. Made sure it was all tight and solid would hate for my brake pedal to not function 😳
Other then that I have been using the pedal for a while now and it all seems to be good have checked that it's still tight which it is ;)
Just got the speed sensor in the post so I'm waiting for the hoist to be free anyone know what the recommend oil is for the RB20DET box?
Okay I have got the speed sensor in the mail from the KA24DE (S13 MODEL) all bolts in nicely :)
Spoke to another guy who did the same swap in his N/A R34 and he said that the car used the speed sensor off the differential (Not sure how that works) but I will give it a shot and test it.
If all else fails and neither of those work I'll buy an S14 speed sensor and test.
Man this has been a rabbit hole 😂
Edited by RB25inside
Needed to edit the speed sensor model
*** UPDATE ***
I have done it the gearbox is in the car and it is rolling :) Car feels so much more responsive with the RB20DET box. Will keep you updated how it goes.
So as it turns out I didn't have to use any speed sensor. The rear drive shaft has an abs sensor which detects speed. So I didn't end up using the S13 speed sensor.
I checked that the Speedo was reading right with two different GPS apps on two different phones and it all lines up. So the R34 GT NA dont seem to need a speed sensor from the gearbox. Instead of runs off the ABS system 💪
  • Like 3
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
