Hello all,
I have just bought my 1992 R32 GTS and have found that the headlight lowbeams are permanently on and cannot seem to fix it.
I unplugged the switch and they stayed on, unplugged the relay and still stayed on.
Wondering if anyone has any advice before I start tracing all the wires back looking for the problem.
Thanks
https://www.sau.com.au/forums/topic/485734-r32-gts-headlights-staying-on/
That's not going to happen, given...
Because that shot should be categorically impossible. Stock circuit goes direct from dash switch/dimmer to globes.
Someone might have added relays and f**ked that up, so that the relays stay on regardless of the control side being on/off/unplugged.
There's a big 3 pin connector (H4 style) behind each headlight that carries the Lo, Hi and earth wires, that plugs into a subloom that breaks out to connect to the separate Lo and Hi globes in the headlight. If there are relays added, they should be there, because it is the easiest place to intercept the stock wiring and interpose something else.
Question: on a stock 32 when the lights are turned on at the dash switch do they turn themselves off when the ignition is off
Assumption: possibly someone wired them so the lights come on/off with the ignition as a simple hack because they always drove with the headlights on....maybe
With most modern cars the lights go out when the ignition is switched off and a door is opened, or after some time, some older cars do this, some don't
I personally always drive with my headlights on, day or night, that is a possible hack that I have considered for my MX5 which beeps at me every time I get out the car because I forgot to turn off the headlights, unlike my VX SS where the lights come on and off with the ignition
What I recommend:
"H4 relay harness" for your Headlights, the R32 switch is passed though the headlight circuit, so it's common to see burn out switches because people have used "100W H3" or H3C bulbs, they are all shit.
ALL BLUE TINTED BULBS ARE SHIT
no matter what instagram ad you saw, every single HID/LED/whatever bulb is shit.
Trust me, been there done that, every halogen bulb is shit.
Your only real upgrade path is to retrofit proper HID projectors and ballast (or equivalent Koito LED projectors).
trust me when i say i've been there done that, no replacement for displacement.
And that's saying with me driving a BMW F45 with factory LED bi-LED, and my R32 having aftermaket bi-Xenon (morimoto d4s)
you cannot argue with physics
4 hours ago, Duncan said:
Before you go too far with this, just make sure it is indeed the headlights on, and not the foglights (switch on the dash surround). Also, are the taillights always on?
Tails are always on aswell even when the car is fully off, I’ve been having to disconnect the battery.
By the looks of it the bloke must’ve messed around with all the light wiring so I’m just going to go through and redo it all.
On 8/15/2024 at 2:01 AM, niZmO_Man said:
What I recommend:
I’ll have to have a look at them then, looks like old mate messed around with the wiring and rooted it.
That switch turns the tail lights on.
On 13/08/2024 at 1:29 PM, slow32de said:
Hello all,
Thanks
This happened to me, Its an easy fix.
The control switch you use to turn on the lights have metal 'tags' inside that switch between the options on your knob. those tags wear out and can easily short.
I bit the bullet and bought another light switch. unfortunately i had to buy the whole surround to get that switch hahaha
Yeah nah, because:
Something is well f**ked up on this one.
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
