19 minutes ago, Dose Pipe Sutututu said:
If you're using an Elite, disable the transient fuel function and use the MAP prediction. It's light years ahead of the transient crap.
The MAP prediction setup looks complex to me, i don't understand any of the 4 pages really 🤷🏻‍♂️. I'll have to do some research
Also, from your experience, should i be afraid of using the LTFT as a means to improve drivability over time?
Edited by ChrisW434
3 minutes ago, ChrisW434 said:
From your experience, should i be afraid of using the LTFT as a means to improve drivability over time?
Not at all, it's there for a reason. Both ST and LT fuel trims are there to be used.
Think of a modern EFI stock car, they utilise both ST and LT as well.
Of course you want to have the injector data, coolant temp, fuel temp, fuel density, baro, air temp tables all correctly defined with fuel trims against them so your LT and ST aren't working hard to meet the AFR targets.
You'll also find that with bigger cams, you might need to target a bit richer than stoich as you'll find it will buckle.
I'll send some screen shots of how I set things up (once Lenovo the pricks send back my laptop, been 3x weeks to replace a mobo under warranty).
8 minutes ago, ChrisW434 said:
Righto, i'll have look into that now. I have the laptop with me, but not the car.
LTFT is a useful tool, but always ask yourself why it's correcting first (I.E is it being too aggressive? is it fighting with decel?). Also more importantly, manually smooth out your fuel map afterwards as it will make it ugly and lumpy after applying.
Edited by TurboTapin
All sounds good, thanks for that. I'm not starting from scratch as the car is tuned prob 95% just trying to clean up drivability myself as it's obviously really expensive to keep paying a tuner for diminishing returns. The fuel tables are set up decent, as is the basic setup.. i think
I mean ideally trims are there because base tables are never 100% accurate. You want them to be as accurate as you can possibly get them, but temperature variations, different altitude, heat, everything likes to mess with how accurate a base table can be.
Fuel trims and Narrowband/Wideband fuel control exist to realistically fill this gap/fuzzy factor, and do their job great. But while they will drag your AFR/Lambda to a target, you want them to have to do as little work as possible.
Don't tweak any of this stuff without a wideband. Unless it's something like "Disable 'Ghost Cam' because it's very obvious when looking into the Tune", you are guessing with regards to your AFR.
You are absolutely right and it's far better to spend the money on a Wideband controller (especially with haltech) and the fab to get it plumbed in NOT where the narrowbands sit (it is supposed to be 1 meter from the turbo), and teach yourself all this little finicky stuff. This is stuff no tuner can ever really be expected to get perfect, but the owner of the car will see SO much livability improvements by learning and tweaking these things - With the proper tools.
It IS the difference between "Oh yeah my tuned car drives a bit like a tuned car" and "My car drives like a factory car"
It does take a lot of time and tweaking and fun, but you'd never want to be paying $150 an hour for someone else to spend that much time on it.
@ChrisW434
If tuning is new to you, this might be really useful -
https://evansperformanceacademy.vhx.tv/
They run a subscription model, so for $50 USD you get access to 100% of the content. Turn it on, watch like crazy for a month and turn it off. The value is crazy.
This is how I learnt to tune many years ago. Since then, I go back to the site every couple of years to catch up on new content. I wish HPA ran the same pricing, they are so expensive in comparison lol.
Love that info, agree with all of it. I have a WB1 controller for it, and i welded the bung around a metre from the turbo down near the transmission. Seems to work well and should not get baked too quickly...
I'm happy to hear others acknowledge the whole "drives like a tuned car" deal as i was initially disappointed after the first couple tunes, but have since learnt the reality. I can only imagine how many hours would be in a factory ecm to get a factory car driving like they do!
Keen to get the LTFTs up and running and maybe i'll see a little improvement over time 👍🏻
9 hours ago, Murray_Calavera said:
@ChrisW434
I have watched a couple of Evans demos on youtube. Pretty good hey. I was considering it, as it looked awesome. Good feedback about it is encouraging so i might subscribe to learn more and get this 90s JDM nugget sorted
  • Like 1
8 hours ago, R32RB20 said:
Hey @ChrisW434 did you end up changing the decel fuel cut? did it work? make sure you post what worked for you, it may help other currently or in the future :)
Hi,
i did try turning off the decel fuel cut, and noticed a positive change when on/off throttle in traffic, but needs tweaking as the car runs on more than i'd like.
So thats still in progress.
Also, i richened up the fuel map slightly and  gave it more ignition advance to smooth out the idle which also helped.
I've got some good advice to follow with other settings also so theres more to do.
  • Thanks 1
Got my laptop back after 3x fking weeks at Lenovo... pricks.
Anyhow, here are some screenshots of my tune and how I've calibrated my shit box.
This is the best thing to come out on the Haltech since sliced bread:
If you make all this say 15 instead of 12 or whatever so there's not a big timing jump between 950 to 1000 the idle won't "brap" as much. I did this because I am a poser
Decel, I find adding in heaps of fuel on recovery stops the idle being aids
Also defining fuel density vs. ethanol percentage vs. fuel temperature immensely improved the car's driveability
Thanks heaps, gonna dive in and look at all this awesome info!
i'll reply once i've look at all this goodness...
  • Like 1
Righto:
pic 1: awesome, and i've found Haltech has good info about this so its cool to see a working example.
pic 2: looks like my current one lol. I'll smooth it out whilst i sort the driveability. The brappy idle is a guilty pleasure though haha.
pic 3: I'll compare that to mine and see how that goes. Looks good.
pic 4: this table has similar numbers in the cells, so i'm guessing this one is quite sensitive to values?
It's just fuel density vs. temperature. I got that data from BP Australia and then interpolate it with E85 data
Thats pretty switched-on 👌🏻
i'm keen to see how the predicted MAP table updates and changes as it gets driven, as the initial generic figures are much different to your displayed ones.
Edited by ChrisW434
  • Like 1
Whatever it takes to make it drive like a M2/3/4 lol.. (on going joke here with me).
Nek minnit in goes a BMW DCT or ZF box
Ha, i'm super fussy with driveability, and it burns that my money pit drives like a "tuned car"
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
