Looking to buy a new radiator cap for my Skyline because I think this one is shot. I've got the part# 2143001F02 and it seems this same part is also the radiator cap for the Nissan Sunny B13?
https://goodstate.com.au/parts/72f01c08ec5ae1878e258c43e35b81aa?srsltid=AfmBOorhguaKBQN0nFfCaM7kjdreG3TrS4nbB3VWZWw8iFXGJtFP-jtw
I mean, the part number matches, so I'm inclined to not overthink it. These are some of the only guys in Aus I could find. Most radiator caps I find are 1.2 and I would feel more comfortable replacing with a stock 0.9 cap. I just wanted to get some kind of confirmation since their website does not show the RB25 or the Skyline as compatible. 🤷🏽‍♂️
https://www.sau.com.au/forums/topic/485764-r34-gtt-oem-radiator-cap/
I know this has been discussed before, but I can see the Fenix radiator is 1.1 bar.
https://fenixradiators.com.au/products/nissan-skyline-r33-gts-t-gt-rfull-alloy-performance-radiator?variant=40947446251678
1. Should I be worried about the extra 0.2 bar pressure that will be going through the whole cooling system?
Car is just a daily, only time it goes over 3K revs is when I'm merging on the highway or sick of being stuck behind a slow car 🤣
2. If I'm so worried, do I just get a 0.9 bar cap?
If you want to be pedantic and justify it. Higher pressure means it needs to be a higher temperature to boil over.
In the real world, it absolutely won't matter at all. You can also tell yourself that an alloy radiator can handle higher pressure than one with 20 year old plastic tanks (it will).
  • Like 1
Realistically, the biggest impact of the higher pressure cap in a daily car is a coolant hose that is on its way to failing will happen a little sooner due to potential for extra pressure in the system :)
  • Sad 1
@Kinkstaah yeah might just be me being paranoid with how much can go wrong!
@Duncan Looks like I'll get replacement hoses for the radiator soon after the radiator then!!!
@GTSBoy Is this the right radiator? It just says R34 and R33 so I'm assuming they all have the same radiator specs?
I read in a guide that there is a sensor on the bottom left? Do those still fit as well?
Edited by DraftySquash
It should be. It's the only option (other than the cross flow, which you don't want, and the one with the shroud and fan, which is the same rad underneath anyway).
As to the sensor, I dunno. I think the spot for it is shown blank on their photos. You would be well advised to a) look on your own to see the sensor is there and that you therefore need to accommodate it, and b) ask Fenix what their provision is. You might need to drill and tap the hole, or they might do it on request or as a standard option or a delete option. (Mine is in an R32, so it's not the same thing, and I didn't order it anyway, so I don't know what we did for mine).
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
