Hi everyone,
Apologies in advance if this feels like a topic covered multiple times. I'm only asking because some of the old topics I found are missing images now.
I'm in the process of getting a manual boost controller (BC). Nothing fancy, just getting a manual one for now as I don't plan to go crazy with it and would not go over 10 PSI. My car is not jacked up on boost steroids to do crazy numbers.
I want to understand the OEM setup of the boost solenoid and vacuum lines on the R34 GTT so I know what needs to be changed when I do install the BC. I sketched the current setup to the best I could see and it's on the diagram attached.
If the boost controller 'Wastegate Arrow' goes from nipple 1 to 2. My understanding is that the red vacuum line's "F" connector-end should be connected to BC nipple #2?
Nipple #1 is meant to have the "pressure source" so what vacuum line would that be? Is it the green vacuum line?
From what I have read here, the OEM boost solenoid is not used at this point. So that can come out and then I can just plug the nipple that usually connects to the blue vacuum line?
So would the final setup look something like this?
Thanks in advance. I don't want to already be knee-deep into pulling out vacuum lines before understanding this. I'm a noob when it comes to boost setups so trying to learn as I go.
https://www.sau.com.au/forums/topic/486110-help-understand-gtt-boost-setup/
The stock boost solenoid is just a valve. Power it and it is open. Unpowered, it is closed.
When it is closed, there is no boost bleed out through the solenoid back to the inlet. The wastegate sees all the boost pressure, thus you get the wastegate's spring pressure as your boost pressure. 5 psi.
When it is open, it lets some boost escape. This causes the static (boost) pressure in the line to the wastegate to be lower than the pressure in the intercooler pipe. There is probably a small restrictor in the solenoid or one of its lines to limit the flow rate of the escaping air, which limits how far the static pressure can fall, which limits the extra boost. The boost has to climb above the original/wastegate setpoint until the wastegate sees 5 psi. You get 7 psi in the intercooler pipework.
A manual boost controller is exactly the same setup, just without the ability to change it on-off. It's always set to whatever you set it to. There is a small leak from the boost controller. The more you screw the adjuster in, the more it leaks, the lower the pressure seen at the wastegate and the higher the boost will be.
So, yes, your diagrams are correct.
  • Thanks 1
@GTSBoy that’s good information and thanks for sharing that.
I’ve read the GTT has 2 stages of boost? 5psi or so at lower RPMs and then 7psi.
So I assume, with a boost controller it will be one standard pressure. I got no issue with that until I invest in an electronic boost controller.
With the setup after the boost controller, should I still keep the solenoid plugged in to power? Just so the ECU is happy? Or does unplugging it and completely removing it cause no issues?
I’ve got myself booked in for a Nistune install and tune next Monday so pretty excited 😝
The ECU doesn't care if the solenoid isn't there. There's no sensing/feedback from the solenoid. The ECU just gives it power, or not.
Make sure that you Nistune tuner knows damn well how to tune a Neo. They suck. You have to take a lot of care to override bullshit to do with the boost sensor and a few other things to stop them being a dick.
On 11/2/2025 at 9:51 PM, Milkmun said:
Who's doing your Nistune install and tune?
Could always ask them to install the MBC.
It’s Shane at CMS performance doing the tune.
CMS performance was the only place in VIC I could find that would supply, install and tune (and had good feedback)
Yeah that might be a good idea 😂
Less chances of fkn it up
Edited by DraftySquash
Big drive from the west to Seaford. Good luck man, let us know how it all goes.
lol I know!!
I’m actually staying over at a mate’s place in SE the night before.
not because I don’t like the long drive. I just don’t want to drive from West to Seaford around 8am on a Monday 😂
traffic would be wild.
The Skyline actually does the West to SE trip without issues. My family is on that side.
I think a 60-90 mins drive is worth it, if the mechanic is good and has experience.
that’s what I’ve heard about CMS, so I’ll let you know how I go after Monday
I have a friend who has used Chequered Tuning and CMS. Went to CMS when Chequered had a long wait time which is kind of the norm (for good reason).
Was very happy - I'm pretty sure the very simple thing you're asking will be simple.
  • Like 1
@Kinkstaah yeah I initially checked with Chequered as I've used them with a previous car. But they have stopped sourcing and installing Nistune chips. They only do tuning now.
I did not want to pull out my ECU and send it away somewhere to have the chip installed. That would mean no driving the Skyline :D
Just putting it out there, that's a decent list.
You would be better off *not* doing *any* of that and buying someone else's modded car. Like mine. Or anybody else's. Yes it's lotto dependent and all this and that but that 70K (remember, double your guesses) could go elsewhere. Keep it stock, save your money, go lowball @Dose Pipe Sutututu :p
  • Haha 2
If someone walked up to me and offered me an amount that I can't refuse, please take it away, I'll throw in half my tools, the boxes of brand new OEM spares, anything in the house I can find that's Skyline related.
Want the lot gone.
(don't mod your car, you'll regret it)
You know what, I'll double or nothing. Save your money, buy a V8 Manual Mustang in 2 years and have a more fun street car with better support and all that. I often tell people "if I could do it all again, I wouldn't".
Sell your R34 GTT to someone, spend the 20k in difference between that and a 2018 Gen2 V8 Manual Mustang. I'll bet you will have the $ in your pocket by the time you spend the ~20K differential on mods and get them installed.
Just planting this seed for future regrets. Blah blah, wisdom of people who would do it differently who are at the end of the road you are just starting on, etc. Car modding is often death by a thousand cuts as you wait to afford the next big mod.
Imagine a 2 door Skyline with a 330KW N/A V8 Revving to 7500rpm like the RB25, with 315's all round.
  • Haha 2
Yeah if the goal is to drive something then modifying a car is a bad idea.
  • Like 1
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
