I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it
Works are as follows
Head
-Extensive porting
1mm oversized supertech valves
Supertech double springs
Supertech valve guides
Supertech titanium retainers
Tomei solid lifters
Tomei 270 x 10.25 cams
Head drain
Bottom end series 2 rb30 block
Cp ceramic coated pistons
Eagle rods
Romac balancer
Oil restrictions
O ringed blah blah spent a fortune
And will get a girdle because the 30s arent used to handling that much rpm
Nitto billet oil pump
Hypertune plenum
6boost mani
Refurbed astra pump thats the cover for it in the boot
I did have a precision 6262 but sold it because drag car life.
Currently building the ass end full 4 link floater rear end with a 2 speed
But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route.
Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
https://www.sau.com.au/forums/topic/486253-rb2630-build/
2630s work perfectly well.
There is something to be said for just using the 30 head, as it saves all the pain of the conversion, still makes tons of power, still sounds cool, etc etc. 2630 will obviously make more power again, but the differences are not stupidly big.
It really depends on whether you're racing for sheep stations or not. If it's dead serious, then it's a 26 head. If it's just for fun, it could go either way. But the 26 head and the effort to get it set up, etc etc, is part of the fun.
  • Like 1
https://www.sau.com.au/forums/topic/486253-rb2630-build/#findComment-8000397
Posted (edited)
Both heads will be equally reliable or unreliable depending on what you do to them.
Stock the RB26 head will flow more. You have access to the stock intake ITB manifold on the RB26 cheaply which flows really well(1000hp+).   Arguably more aftermarket support for RB26, though in Aus we love our RB30 SOHC heads too.
The only downsides to the RB26 head is if you have a VL commodore and want to keep the SOHC look.
Where you may have an issue is drilling out the rb30 block for the bigger head studs but if you are building a big power motor you'd probably put bigger studs on the SOHC head too.  This is just about finding a good machine shop, sometimes easier said than done.
RB30 head worked can make big power just like a Rb26 head, so really it actually more comes down to what your preference is for your car.  People now even making billet versions of both.
Edited by Butters
https://www.sau.com.au/forums/topic/486253-rb2630-build/#findComment-8000398
13 hours ago, MBS206 said:
And if you want more power, more reliably, and cheaper, go get the Aussie RB... The 4L Barra and put that in instead.
No doubt barra is a great cheap way to make power but... so many around now I just call them cabs lol. And low revving compared to the rb doesnt sound anywhere near as cool haha. And talk about sacrilege, i love the rbs jist something about them
https://www.sau.com.au/forums/topic/486253-rb2630-build/#findComment-8000416
7 hours ago, r32-25t said:
You’ll want to have the block drilled and tapped to suit 1/2in head studs and the head for the same.
How much power do you intend to make?
Years ago I wanted allllll the power but realistically 700hp would be more than enough for what I want. I started the build with the intention of dragging it. But times change family etc I just want a mad streeter than I can take to powercruise.
https://www.sau.com.au/forums/topic/486253-rb2630-build/#findComment-8000417
Been looking at PRP and how much work and development they've put into making it easier to put the 26 head on. They even make this bracket to tap the idler pulley on, its so awesome how far that stuff has come in the last 10 years.
https://www.sau.com.au/forums/topic/486253-rb2630-build/#findComment-8000418
2 hours ago, lilley's gtr said:
If anyone has done a similar build I'd love to see what they did and why
To help you out... If you head for the "Forced Induction" section of the forum, you'll find these two threads.
RB30 Hybrid Dyno Results.
RB30 Conversion Thread
https://www.sau.com.au/forums/topic/486253-rb2630-build/#findComment-8000429
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
