Has anybody had their wheels refurbished? I reckon it's likely bloody expensive. Even a sand blasting quote for my 17s was 200-300 per wheel!
The E39 wheels are basic BMW M Sport (or M Tech at the time.) they have slight rash and some have signs of bad repair in the past on the lips. The main issue is that they've become really off coloured.
I think it will be too much as this is definitely (supposed to be) a budget resto.
I've been looking at others for sale but they all have some minor damage and colour issues.
In the end I think I'll just need to sand blast them myself and do a respray.
https://www.sau.com.au/forums/topic/486286-wheel-refurb/
29 minutes ago, dyl33 said:
I got a quote to restore a set of Volk racing gtc wheels at a wheel restoration shop which involved repainting the centres fixing some small gutter rash and repolishing them and the quote was $2.5k
I ended up getting them sandblasted and powdercoated for $240
Yeah this confirms what I was thinking. Volks are worth a crap load more than my M Sport 17s and 2500 is nuts!
240 is crazy cheap, was this 20 years ago?
I have a fairly good air compressor so I'm tempted to get an eBay sand blaster.
https://www.sau.com.au/forums/topic/486286-wheel-refurb/#findComment-8000752
11 hours ago, GTSBoy said:
Keeping in mind that sandblasting is really aggressive on softer metals like cast alloy, and you can do damage that you might regret. For trash wheels, not a problem. For wheels with value/scarcity issues, etc.... perhaps a less aggressive media is a better choice?
I was wondering about this. I'll do some research.
https://www.sau.com.au/forums/topic/486286-wheel-refurb/#findComment-8000763
  • 4 weeks later...
4 minutes ago, Duncan said:
On the bright side they should come back perfect....until the first time you make a mistake parallel parking.....
But, curb rash is easy and relatively cheap to fix.
It's the imperfections on the rest of the wheels that I'd like to see gone. Don't want to spend big money on wheels that are out of production though. I'd be so worried about breaking one afterwards on the offroad-adventure that is Sydney roads these days. :(
Following this topic with interest.
https://www.sau.com.au/forums/topic/486286-wheel-refurb/#findComment-8001600
I got a quote to refurbish some BBS look-alikes -best part of 2k.
I had some alloys sand blasted - bad idea, in retrospect. Had to wear gloves to handle them! I had them powder coated to protect the rim.
Rather than sand blasting, I recommend hydro blasting (blasted with micro-fine glass beads carried in a water stream). I had a set of TRX rims done recently for only about $200 total.
https://www.sau.com.au/forums/topic/486286-wheel-refurb/#findComment-8001628
Do you have any before and after photos? That's $200 just for the hydro blasting?
https://www.sau.com.au/forums/topic/486286-wheel-refurb/#findComment-8001655
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
