Hello , im new here and i have A31 home build
RB25det neo stock eng / turbo
aem ems 2 blue connector
aem 3.5 map
aem cas disk
aem wideband connected to ecu
355 lph pump
550 nismo yellow injectors side feed
aftermarket regulator
and won’t start with base aem tuner basic tune
eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle
Now it won’t start
Wideband reads 10 and 11 at lowest fuel setting
and will share calibrations soon for aem tuner i think something is wrong in aem tuner
please if you have any information, am very grateful
https://www.sau.com.au/forums/topic/486463-cas-issue/
6 hours ago, nash47 said:
Now it won’t start
The wideband reading is meaningless if it's not running.
Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that?
Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
https://www.sau.com.au/forums/topic/486463-cas-issue/#findComment-8003487
aem 3.5 map
aem cas disk
355 lph pump
Now it won’t start
Your best and only option is to verify your CAS is reading properly with an oscilloscope (I'm presuming the V2's had a built in one) and then properly sync your ignition and mechanical timing using your offset angle within the ecu. I don't understand why you flipped your CAS.
Edited by TurboTapin
https://www.sau.com.au/forums/topic/486463-cas-issue/#findComment-8003494
I'm going to assume they flipped it, as the timing setup in the AEM is catastrophically wrong.
Once it is fixed, they'll likely need to swap it back to normal.
https://www.sau.com.au/forums/topic/486463-cas-issue/#findComment-8003497
5 hours ago, nash47 said:
This is aem disk setting in aem tuner and still 180 dgree off or ignition on exhaust cycle is it from cas it self as cas seems wouldn’t fit in cam shaft if wrong position and wiring been verified any ideas
Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
https://www.sau.com.au/forums/topic/486463-cas-issue/#findComment-8003644
4 minutes ago, nash47 said:
Yes sir am asking is there possible way from aem tuner from wiring pins
It will be a software setting.
I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on.
If it were Link or Haltech, someone would be able to just send you a ECU file though.
https://www.sau.com.au/forums/topic/486463-cas-issue/#findComment-8003664
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
