My package came in early. I noticed that in the instructions (this is labeled a 2024 model) they no longer indicate that the diff can be "Adjusted" as I have seen in older post, however they now list specific part numbers for each version of the diff. Interestingly they also show a 1.7 way LSD which I never saw in the parts catalog, but it's a variant of the 1.5 way (of which I think this is just a pinion flip).
 I am not going to upload all the pages of the manual as some are just disassembly and install by professional warnings.
The first page is all the different part numbers associated with the kit. Note for the GT-Pro there is 3 LSD PN's 20 17 and 15. (see bottom for appendix of images)
The first photo is how it came assembled in the kit as 2 way. notice how the side flange ramps are actually different angles and the pinion ramp matches those angles.
Now I have flipped the pinion, so the side ramps are still in 2 way, but the pinion ramps are miss matched giving the decal ramp a gap and a more aggressive position. I believe this is a 1.5 way configuration, but I am not sure which version the standard 1.5 or the 1.7 (45* ramp)
this is the default 1 way... you can see the solid back of the pinion engages the side flanges. the diffs spring loaded sides should mean this completely prevents any spreading to engage the decel gate.
My original suggested 1.5 way. this is with the pinion flipped from the original way, you can see the 1 way side ramp is resting on the pinion ramp. meaning on decel the differential will twist and lock up the side flanges.
 IMG_1414.thumb.jpeg.7651b639584f749b305796df7b6d888d.jpegIMG_1415.thumb.jpeg.d22c7e36dbf3ab8815e26f8a7d493e2a.jpeg
Appendix images
IMG_1403.thumb.jpeg.d2e07a165e573a0d1e570dd703ef098b.jpegIMG_1404.thumb.jpeg.da69071597b1b98127669728c2e9e623.jpegIMG_1405.thumb.jpeg.eb952f91eb6577cef0b14a16c79f1c9d.jpegIMG_1406.thumb.jpeg.c3d1e622b49729b3c78508c29b84a99f.jpegIMG_1407.thumb.jpeg.566c1ca76b45cc64e47b2b4b0019d0a5.jpegIMG_1408.thumb.jpeg.a1825335e17104da384bac53ef56dd77.jpeg
  • Like 3
  • Thanks 1
This is the one that I don't think you could actually assemble. Look how far apart the side flanges are compared to the other configurations.
I've got the same diff as you in the 2 way configuration.
I didn't know this was a thing, thanks heaps for posting this up.
Valid point, I did not consider that.
1 hour ago, Kinkstaah said:
I'm assuming you ordered the 38420-RSS20-B5?
Yes, this was the only one available in the states. Everything else I would have to import.
I am not saying this is a correct config. thinking about my ramblings with this diff, those sharp edges or off angle ramps are probably bad for the health of the diff and should not be considered, so I would only run this diff in the intended 1.5 way or 2 way
I have reviewed the catalog more, and realized it was always in front of my face... they consider a 1* ramp angle a 1.5 way... so what everyone considers visually a 1 way is their 1.5 way. Which is wild to me to think that a 1* ramp makes it a 1.5 way. However this is backed up by a few older instruction pictures, and the motoIQ stuff.
page 113 https://www.nismo.co.jp/products/web_catalogue/pdf/catalogue_2023.pdf
or
the product page https://www.nismo.co.jp/products/web_catalogue/special/gt_lsd/
I think I am going to stick with the diff in the 2way position; its probably not going to feel much different than my GT already does, but its fresher, plated better, and I can adjust the preload, 🤷‍♂️.
  • Like 1
Wait, so the ACCELERATION ramp is 55 degree on both configs, and decel is 45 degree on the 2 way? (or the 1.5 because it's not the same blablablabla).
That would match my experience, insofar that the decel lockup is harder than the accel lockup. It was absolutely stupid to use on road configs, but I found out later my subframe was solide-r than most.
It is however great to know for sure what many had been suspecting, and ultimately the 1.5 and 2 way in GT Pro form are really the same part, it's just what state it's configured in when it comes to the customer.
yes, the 2 way is 55* on accel, 45* on decel. where as the 1.5 way is 55* on accel, 1* on decel.
where as ATS lsd looks like it uses something more like 5-20* ramp for their 1.5 way
The terms i've always heard have been 45deg (most 'force/lock') to 90 degree (no, force/lock)
So 45 degree is more locky than 55 degree. Which seems odd from the perspective of lock on decel versus accel. I suppose it IS a race part, so inciting rotation on corner entry is actually what it was, you know, designed for.
Nah Nah Nah.
The drive side is on the right. You can tell, because the 1-way opening has its 1° angle, decel side on the left, and so the 2-way opening must be overrun on the left too. The overrun ramp on the 2-way opening is steeper (ie, closer to the ineffective 1-way's 1° ramp) than it is to the drive side's angle to the right. The drive ramp is 55° FROM THE VERTICAL. The decel side is 45° from the vertical.
What that amounts to is, the more laid down towards the horizontal the opening's ramp is, the more spreading effect that cam has on it as the cam rotates.
Compare that to the ATS graphic posted above, where you can clearly see the difference between the angles on a real 1-way, a real 1.5-way, and a real 2-way (where the ATS 2-way actually appears to have the same angle on both accel and overrun ramps).
2 minutes ago, Kinkstaah said:
I would think the left side of this is 45 degree and the right side of this is 55 degree. There'd be more pressure with this going left than going right....?
It's about how easily it can move it too. It needs more force to go left being at a steeper angle. So since it needs more force, it's going to mean it takes a lot more effort (slip) to get it to push out. As to the right is easier to spread, it's going to be easier for it to lock up.
Yes.
Do  thought experiment. Make the left ramp, the 45° ramp, one degree steeper. It will then be 44° from the vertical. What happens to the forces? Too hard to tell? Well, add one more degree, and then keep doing that until it looks exactly like the near vertical wall of the 1-way opening. I would suggest that every degree less than 45° (from vertical) reduces the reaction force, if continually removing them from 45 gets you back to the 1-way profile.
I agree, thus 45 degree is the *max* force one could apply to it. This is similar to what I've seen in uh... simulations... which allow you to play with diff ramp angles.
Anything higher (or lower) than 45 degree would produce less force as 45 is the max... triangley. :8_laughing:
I would state the 1 way is 90 degree, at least this is how my brain and other ways of explaining it refer to it. 90 degree also effectively acted completely open. I realise Nismo refer to it not as 90 (or 89) but "1". So I'm not understanding the angle on which these angles are based.
It's the angle of the ramp from the vertical.
You're measuring from the horizontal.
To convert, take 90* minus your angle reference = Nismo Angle.
Also, it is just about triangularity. The less angle, the easier it physically is to do.
Think of the amount of slip you're getting, as how hard you need to push an object.
More slip, equals pushing way harder.
Then the ramp is how steep the hill is. The Accel is less slip, which means it takes less pushing (less slip) to get it to be able to push apart.
However, the steeper sides on the decell means it will take a lot more pushing (slip) to get it up the ramp.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
