The install looks realy great... but
How do you change the bulbs? have you got pull out pannels etc??
Thanks Dean
Change what bulbs? The rear lights? Well the trunk is made up by sections, so the section covering the rear of the trunk can be removed to display the rear bulb holders.
I dont know what you mean about "pull out pannels etc"? ;)
Regards
Håkan
  • Replies 59
so where do you carry your spare wheel now !!!! lol
mate the peach coloured skyline beside your car at the show, if ya know him i love to get that colour code of him , its awesome
your set up rocks to , gives me some food for thought......
To ALL,
I didnt do it at the time of our stereo install,however i came up with the idea after and one of the lads in our club did it to his '33 prior to fitting up his install.Got you wondering what i'm talking about?The idea is so simple and not too much harder to achieve-------cut out the spare wheel well in your boot turn it upside down and reweld it back in place.Took a couple of lazy hours to complete on a sunday.You still have ample space for a serious install and can fit a space saver under the car for your long cruises and interstate trips.
Regards,
SKYLINE (Kym)... :headspin:
I have no room for a spare wheel. I have my spare wheel on a can, so to speak. High preassure foam. :thumbsup:
Regards
Håkan
Ps. About the peach-colored R33, he is known as "SkylineMecken" at the forum of www.skyline.se ;)
Just wondering how you went installing the Pioneer AVH head unit. I got mine installed but in the skyline the oustide bracket/cover/plate doesn't seem to fit very well. I shaved down the sides so now it slips in & the top can clip in but it looks like the bottom is a bit low now too. So only the top seems to clip in.
Just wondering how you went :P
Cheers,
Penfold
  • 2 months later...
Im sorry I dont have any buildpics from the head-unit install. But all I can say is that it sticks out a bit, I will try to take a good picture of how it looks more in detail.
Regards
Håkan
got a few questions for ya mate first off
what did they use to mold the carpet is it fiber glass or plaster
how did they get the mold out once was dry did they just cut out the few sections and pulled it out cause i thought it would have been screwed down did you have to get the screws out as first and how hard was that
was is hard to cut the sections out with out damaging anything under neath
i ask because im about to atemp this myself very soon and it seems like the best way to do it but i basicaly need to know what was it molded with and how did you get it out of the boot once was dry thanks
Thanks.
The system is built for quality sound (but I did a test with just the trunk subs, measuring inside the coupé of 129 db). Now the back seat has gone and it is playing alot louder, not measured though, but it sounds great!
/Håkan
First wood, then fiberglass and then glue to hold the carpet against the shape of the fiberglass.
The sections were made separately and placed and screwed together, so it is easy to remove for service/update.
/Håkan
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
