  • Replies 55
VG20 ?? Why don't you get a better turbo ? You a prolly blowing heaps of hot air - and by raising the boost makes it worse.
Sure you can cool the air with an intercooler - but wouldn't it be better to not let the air get so hot in the first place ?
Cheers,
there is a host of other factory nissan bits from various nissan cars that you need to install the Greddy. The manual that comes with the intake plenum gives you all the part numbers. A nissan dealer should be able to hook you up.
My 20 cents worth, richen it up NOW. Don't wait to buy some parts, 13 to 1 A/F ratio is more than I would consider running for 1 day. You don't need a FMIC or a plenum to fix lean A/F ratios. But if you don't fix the A/F ratios you are going to need a new engine, maybe tomorrow or maybe the next day. :Bang:
Have you checked your Plugs and Coil Packs ? Looks very similar to a r33 gts-t we run up on the dyno with a couple of coils a little dodgy.
And yes invest in a bigger fuel pump they are a man’s best friend when you own a skyline.
Other wise you will be singing the song .. number 6 da da…… I melted piston number…. 6 da da…
13_devil,
Doesnt mean that if it only happens at 5000rpm it will not destroy ur engine in the long run.
I believe the problem doesn't just occur suddenly at 5000rpm but it may build up slowly until it's noticeable enough at 5000rpm to show up on dyno graph. so it could start to happen at a lower severity (hardly noticeable) at 2000, 3000, 4000 rpm. keep running it over and over and after a while it can just go bang at the time u least expected. After a while the problem may shifted to 4000rpm at 4th gear, then as it goes worse it can be at 3rd gear 3000rpm until the whole engine seized.
I'd say get it fixed dun ignore it. See my dyno graph below right when still having same pinging problem with yours, and below left after I fixed it (my fuel pump not supplying enough pressure). It only happens last yr at 5500rpm and raised boost, this year it happens at stock boost as low as 3000rpm engine start pinging cos leaning out. Lucky i fixed it and compression test shows engine is still healty (was running stock boost over 1 yr since 1st problem detected).
Cheers,
rs
Edit: stupid attachment, the one i attached first turns out to be on the right.
I'm speaking from personal experience.
My car used to ping at anything around or above 4000rpm, some days it would, some days it wouldn't.
Being the stubborn and over enthusiastic child I was, I kept going, pushing it and driving it with the "she'll be right mate" attitude.
One day it started blowing smoke, then abit more, then abit more - till the motor died!
And guess what? This was a STOCK engine! Except for a Cat Back Exhaust and guess what else? Front Mount Intercooler (800 x 300)
What I suggest to you, check your injectors or get them cleaned straight away, check the timing, it may seem it's not touched but a careless belt change may have knocked it out.
I have a new engine now (RB25DET) and with Full Turbo Back Exhaust and Front Mount Intercooler I have not heard one ping whatsoever.
Relating to the main question being asked... IMO a plenum is a good move for a few reasons (even with standard turbo)... But the main ones is that it reduces the piping and the next is the throttle response... Made an enormous difference on my car...
my 2 cents... :D
my 2 cents...  :)
If I spent $1,500 on a turbo upgrade and you spend $1,500 on an inlet plenum I'll bet my car is faster. :D
thanks everyone for the reply :)
Im going to get myself a powerfc, at the end on the month; get it tune up and hopfully that will fix the problem :)
The car just got its major serives, so everyone is ok (as injections, plugs, timing belt, timing etc)
but yeah im running only stock boost at the moment and no pushing the car hard so im hoping it will last for a month
    • Kinkstah, no, coilovers aren't illegal, especially as a bolt straight in. The illegal part will be if they're altering suspension geometry beyond factory limits, or the ride height is not legal.   Sounds like the blue slipper just didn't want to deal with any later possibility of mods appearing on the car.
    • The problem has always been that coilovers are able to be adjusted, almost at any time, to be too low. Most people who ever get/got defected for/with coilovers were actually afoul of the minimum ride height rule. So the interpretation by cops/inspectors was always that it is pointless to allow numpty to raise his coilovers and get the car inspected/cleared, then just drop them back down again as soon as they get around the corner from the inspection station.  This led to the interpretation that they were illegal unless rendered such that they can't be adjusted (ie, collars welded to the body, that sort of thing). That may or may not have ever actually been the official line, but I'm pretty sure it's not considered to be a solution these days. Coilovers themselves fall under clause 3.2 b of that manual, because they are an "installation of a variable ride height system" and they don't fit the exclusions in that clause (which point to air springs and other pneumatic adjusters). So, as per previous statements, they require engineering cert to be legal on the road. Once you have such cert, provided you do not adjust them outside the height range covered by the cert, you are OK. Without, you have an unroadworthy vehicle.
    • Here E10 is the cheapest fuel. And general advice is to not use it unless you hate your car. From what I remember it clogs up stuff in the fuel system or injectors?  With US/Canada being E10 across the board, does that mean that all fuel there is terrible?
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW ) Edit: I checked. They aren't. https://www.nsw.gov.au/sites/default/files/2021-02/RMS-infosheet-light-vehicle-modifications-manual-suspension-and-ride-height.pdf
