Just to let everyone know there is going to be a phone poll on Channel 9 news tonight about the new amendments to the laws. I encourage everyone to phone up in the negative and get many others to do it. It might not mean much but it is a voice.
I, in the meantime am trying to get someone in news to put an alternate view of the story up.
https://www.sau.com.au/forums/topic/51529-anti-hoon-laws-phone-poll/
Phone Polls are revenue raising just like anti-hoon laws :cheers: but at least there is a good reason to vote in it.
Have you got a number to call? I'll try to if I get home in time (mobile flat) or is it being done all tonight/tomorrow for the results to be on Tuesday night?
Being done tonight. 10/09/04 Results tommorrow.
The number will go to air at 6:05 tonight. You have around 24 hrs to vote.
As I said it might not mean much but it does show the 130,000 or so people who will be watching that there is opposition to this spurious law
only 2100 calls total thats f*** all
nah you've got heavily biased people that will say that 60% against the law is too close to 50% so the 40% of wankers voting for will be shown as having the overwhelming support.
No hijacking a person's number doesn't cost me money at all.
i've **um** seen it before done with dialer trojans latched onto someone's computer that does winfax through the dialup modem.
Basically since the trojan just keeps dialing a number through the modem.
The winfax program that came with win98se allows the modem to be used as well to call people aswell as fax.
Don't think its possible to do it through broadband because of the digital signal and the net doesn't access the analog signal.
Hmm must find out if Michelle uses dialup at home cause won't it be funny that the voting poll is like 10000000 against to 900 and she gets racked for a $million dollar phone bill
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
