I am wanting for my r32 to get off the boat, but last night was shattered to see a HSV sedan 260kw version totally smash an r32 gtst in a drag.
The r32 was man, had exhaust, could see front mount, and boost gauge. the HSV also manual but looked stock. They both tried as they both skidded on take off and reved the @##4 out of it.
Should this be happening?
https://www.sau.com.au/forums/topic/52070-r32-gtst-vs-hsv/
In the RB25DET i have no problems ripping down HSV's with the 285 badges on the sides. They will always get the head start because of our buddy turbo lag but then the main concentration is to keep traction. To beat a HSV your power has to be above 200Kw otherwise you stand no chance.
https://www.sau.com.au/forums/topic/52070-r32-gtst-vs-hsv/#findComment-1027379
hehe, well they did say "Reason why god created turbo lag, was to give V8s a chance"
:jump:
https://www.sau.com.au/forums/topic/52070-r32-gtst-vs-hsv/#findComment-1027907
really chris? i thought you were on your L plates? being 17 and all...
https://www.sau.com.au/forums/topic/52070-r32-gtst-vs-hsv/#findComment-1035103
Thanks for stories and comments lol.
Knew r32 was never going to be racing menace but hey just something about the guys in commos where I'd love to be able to beat them in a 15k car compared to 90k or whatever they are.
Sorry didn't see if r32 driver was p plate driver or not - but sounded like he left second gear on the road - it crunched in pretty hard!
rookie or rich i guess.
https://www.sau.com.au/forums/topic/52070-r32-gtst-vs-hsv/#findComment-1036310
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
