For those who have found a (one) huntsman in their car, I seem to recall hearing that huntsmen pair up (not sure if for life) so if you find and kill one, you probably have its other, very pissed off, mate/partner in the car with you as well.
On that note, safe driving. (and I wonder if they found a nice place to lay their eggs)
  • Replies 90
oohh that one behind the clock looks nice. yummy
had me a spider in my shower the other nite. it was trying to climb up the wet screen. it kept on falling down. amusing, but SOMEONE(looking in cocos direction) would die. i used to be terrified beyond beleif of spiders when i was younger, (prob because i used to live in a infested house. whenever i went into the bathroom i used to check every possible place a spider could be before showering. uhhh.
my cats name is coco
im so glad to see im not alone. i almost had an accident when a huntsman crawled out onto the sunvisor in front of my face. i swerved off the road into a driveway and jumped out. refused to go within 5 metres of the car until i could see the dead carcass. my mate thought it was hilarious until he realised i was serious and had to find it and kill it before we could go anywhere.
Somehow just having the link the these fella's in this thread didn't seem to be enough.
But they are not as big as they look, that's the dude's sleeve on the right of the picture.
Still big enough but!!
coco, they've probably nested in your airvents, so when you put your heater on full blast their spawn are gonna come flying out at you and sting you to death...
ffs they're just spiders, they're intelligent enought to know that if you f**k with a 6 foot mammal you'll most probably gonna end up gettin squished. they use their venom to hunt shit to eat, and they know they can't eat you. they'll only use it on you if you act like a tard n poke it with a stick or something like that.
Whitetails on the other hand are the bastards of spiders... they'll sting you just to confuse you so they can make a quick retreat, unfortunately their sting makes body parts rot. :(
lmao... :(
id like to see coco in a car during a 45 degree day. He'd be too scared to turn on the air conditioning knowing that... i wonder if he'd rather have a heat stroke than turn on the AC
But like funky said, huntsmen are probably scared more of us than we are of them so im pretty sure if a spider could do a "get-this-human-off-me" dance it would be worse than coco's trademarked one.
My suggestion is to confront your phobia, possibly take a bath with a tub filled with huntsmen... just like on Fear Factor (god i wanna go on that show).
That is just nasty !!
Is that a hunstsman in the picture above ?
I am scared witless of spiders and the biggest ones you get in the uk are about 1/10 that size !! there is no way I could even contamplatedealing with something like that bite or not it is feckin huge !
I once had a spider deop off my sun visor in front of me was about 3cm across including the legs and I nearly crashed my car. I think I'd just pass out if one of those bad boys jumped out on me.
/Steve the wimpy uk muppet
Dont trust little spiders they are sneeky bastards. :)
Big spiders do have a few advantages:
1. its harder for them to hide.
2.you can here them comming (the 8 footsteps)
3. when they bite you its easy to tell. The limb is missing or the puncture marks are the size of bullet holes. :skull:
Yeah we get decent sized spiders at my place all the time, it's an old 2-storey wooden place so there's heaps of places for them to hide and they've had many many years to do so. It's pretty common for us to get spiders the size of my palm, and not surprising to occasionally find one nearly as big as my whole hand. It's farkin excellent when we have exchange students... :bahaha:
When Mum's rellies from England came here a few years back, they spotted a daddy long legs, crapped themselves a bit but after an hour or so they were OK. Then one of them spotted a huntsman (one of the biggish ones that goes out about one knuckle from the palm) on the wall in the bathroom and they very nearly booked into a hotel :D
lmao @ 4ds, funny stuff mate :)
when they byte you
Haha nerd :)
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
    • I neglected to respond to this previously. Get it up to 100 psi, and then you'll be OK.
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
