Hey Guys,
I need somebody to help me with skyline specs and info for a section I am making. I know a lot about model numbers, engines etc - but i still need some assistance in doing it. I am doing the same for Stageas and Cefiros also. Its about time it was all documented on the site.
Christian
https://www.sau.com.au/forums/topic/52367-skyline-guys/
i can get you any spec you want off jap manuals, brochures and stuff. All the stuff I'll be putting up soon on www.japimports.info
you can check out the DIY/FAQ section for my R32 onwards skyline spec/model name/original price list.
https://www.sau.com.au/forums/topic/52367-skyline-guys/#findComment-1035039
check my thread c210/c211 skylines...in the classic skylines forum.....that basically is all the info avail online about that model....i have been researching for over a year on these....
in the UK we only got the C210 as a two door coupe with an injected 2.4 straight six. In Japan the car came as a coupe, four door sedan and an estate. They also came in long and short wheelbase versions, the latter having four cylinder engines. The saloons and coupes also came with a choice of independant or solid rear axles depending on model. Engines varied from a 1600cc four cylinder, to a 2000cc straight six turbo. There was even a diesel version.
They came out in Japan in August 1977 and were sold until August 1981 when they were replaced by the R30 Skyline. Here they were sold from late 1978 and were about $6760 new. The first generation came with the twin round headlights which were changed to large rectangular lights in late 1979. We only ever got the square tail lights as used on the Japanese four cylinder models. The classic twin round tail lights were only used on domestic models. There is one C210 in this country with the twin round tail lights.
The C210 is very similar to the C230 Laurel sold around the same time. In fact almost the entire under structure is the same as a live axled four door Skyline. The coupe C230 Laurel (not sold here) has the same IRS as our Skyline coupe.
1955 Skyline ALSIS
Engine: GA-4
Type: ohv4
Capacity: 1484cc
Bore x Stroke: 75x84
Horsepower: 73
Torque: 87 ft/lb
Compression Ratio: 8.3:1
Carburetor: ----
Gears: 4-colum
Brakes: drum/drum
Speed: 130 km/ph
Length: 4380mm
Width: 1675mm
Height: 1535mm
Weight: 1351kg
1955 Skyline Deluxe ALSID
Engine: GB-30
Type: ohv4
Capacity: 1862cc
Bore x Stroke: 84x84
Horsepower: 83
Torque: 109.2ft/lb
Compression Ratio: 8.5:1
Carburetor: ---
Gears: 4-coloum
Brakes: drum/drum
Speed: 140km/ph
Length: 4380mm
Width: 1675mm
Height: 1535mm
Weight: 1325kg
1961 Skyline Sport BLRA
Engine: GB-30
Type: ohv4
Capacity: 1862cc
Horsepower: 83
Torque: 109.2 ft/lb
Carburetor: ---
Gears: ---
Brakes: drum/drum
Speed: ---
Length: ---
Width: ---
Height: ---
Weight: ---
1961 Skyline S50
Engine: G-1
Type: ohv4
Capacity: 1484cc
Horsepower: 73
Torque: 87 ft/lb
Carburetor: ---
Gears: 3-col/4-floor
Brakes: drum/drum
Speed: 140 km/ph
Length: 3990mm
Width: 1495mm
Height: 1435mm
Weight: 935kg
1965 Skyline GT-A S54AE
Engine: G-7
Type: ohc6
Capacity: 1988cc
Bore x Stroke: 75x75
Horsepower: 106
Torque: 116 ft/lb
Compression Ratio: 8.8:1
Carburetor: 2b-dd 32-32
Gears: 4-floor
Brakes: disc/drum
Speed: 170 km/ph
Length: 4235mm
Width: 1495mm
Height: 1410mm
Weight: 1055kg
1965 Skyline GT-B S54BE
Engine: G-7
Type: ohc6
Capacity: 1988cc
Horsepower: 127
Torque: 123 ft/lb
Compression Ratio: 9.3:1
Carburetor: 3x 2b-sd 40mm
Gears: 5-floor
Brakes: disc/drum
Speed: 180 km/ph
Length: 4235mm
Width: 1510mm
Height: 1405mm
Weight: 1105kg
1967 Skyline C10
Engine: G-15
Type: ohc4
Capacity: 1483cc
Bore x Stroke: 80x70.2
Horsepower: 94
Torque: 96 ft/lb
Carburettor: 2b-dd 28-30
Gears: 4-col/4-floor
Brakes: disc/drum
Speed: 160 km/ph
Length: 4200mm
Width: 1595mm
Height: 1405mm
Weight: 935kg
1967 Skyline GT GC10
Engine: G-7
L20
Type: ohc6
ohc6
Capacity: 1988cc
1998cc
79x69.7
Horsepower: 106
112
Torque: 116 ft/lb
120.8 ft/lb
8.5:1
Carburettor: 2b-dd 32-32
2b-dd 24-28
Gears: --
Brakes: disc/drum
disc/drum
Speed: --
Length: --
Width: --
Height: --
Weight: --
1967 Skyline GT-R KPGC10
Engine: S20
Type: dohc 6
Capacity: 1988cc
Bore x Stroke: 82x62.8
Horsepower: 160
Torque: 130.7 ft/lb
Compression Ratio: 9.5:1
Carburettor: 3x 2b-sd 40mm
Gears: --
Brakes: disc/drum
Speed: --
Length: --
Width: --
Height: --
Weight: --
1973 Skyline GT-R KPGC110
Engine: S20
Type: dohc 6
Capacity: 1989cc
Bore x Stroke: --
Horsepower: 160
Torque: 18.0 kgm
Compression Ratio: --
Carburettor: --
Gears: 5MT
Brakes: disc/disc
Speed: --
Length: 4460mm
Width: 1695mm
Height: 1380mm
Weight: 1145kg
https://www.sau.com.au/forums/topic/52367-skyline-guys/#findComment-1035047
1989 - 1994 Nissan Skyline R32 GT-R
Engine: RB26DETT
Type: Inline 6 dohc, twin turbo
Capacity: 2568cc
Bore x Stroke: --
Horsepower: 280
Torque: 266 ft/lb
Carburetor: --
Transmission: 5M
Brakes: vented discs
Speed: 150 mph
Length: 4545mm
Width: 1755mm
Height: 1355mm
Weight: 1500kg
1989 - 1993 Nissan Skyline R32 GTE Type X
Engine: RB20E
Type: Inline 6 OHC
Capacity: 1998cc
Bore x Stroke: 78mm x 69.7mm
Kw: 92Kw
Torque: 172Nm @ 4400rpm
Carburetor: --
Transmission: 4-Speed Automatic
Brakes: Vented discs (front) discs (back)
Speed: --
Length: 4580mm
Width: 1695mm
Height: 1340mm
Weight: 1260kg
1989 - 1993 Nissan Skyline R32 GTS-t/GTS-4
Engine: RB20DET
Type: Inline 6 dohc, turbo
Capacity: 1998cc
Bore x Stroke: --
Kw: 160Kw
Torque: 263 Nm
Carburetor: --
Transmission: RWD
Brakes: vent disc, 4 pot f't calliper, 1 pot rear, ABS
Speed: --
Length: 4530mm
Width: 1695mm
Height: 1320mm
Weight: kg
1989 - 1993 Nissan Skyline R32 GTS Type J
Engine: RB20E
Type: Inline 6 DOHC 24 valve
Capacity: 1998cc
Kw: 114Kw
Torque: 184Nm @ 5200 RPM
Compression Ratio: 10.2:1
Carburetor: --
Transmission: 4AT FR
Speed: --
Length: 4530mm
Width: 1695mm
Height: 1325mm
Weight: 1290kg
1989 - 1993 Nissan Skyline R32 GTS Type S
Engine: RB20E
Capacity: 1998cc
Kw: 114Kw
Carburetor: --
Speed: --
Length: 4530mm
Width: 1695mm
Height: 1325mm
Weight: 1310kg
1989 - 1993 Nissan Skyline R32 GTS Type X
Engine: RB20E
Capacity: 1998cc
Kw: 114Kw
Carburetor: --
Speed: --
Length: 4530mm
Width: 1695mm
Height: 1325mm
Weight: 1310kg
1989 - 1993 Nissan Skyline R32 GTS25 Type S
Engine: RB20E
Capacity: 2498cc
Bore x Stroke: 86mm x 71.7mm
Kw: 132Kw
Torque: 225Nm @ 5200 RPM
Compression Ratio: 10:1
Carburetor: --
Transmission: 5E-AT
Brakes: Vented discs (front and back)
Speed: --
Length: 4530mm
Width: 1695mm
Height: 1325mm
Weight: 1360kg
1989 - 1993 Nissan Skyline R32 GTS-t Type M
Engine: RB20DET
Type: Inline 6 DOHC 24 valve IC Turbo
Capacity: 1998cc
Kw: 158Kw
Torque: 265Nm @ 5200 RPM
Carburetor: --
Speed: --
Length: 4530mm
Width: 1695mm
Height: 1325mm
Weight: 1340kg
1989 - 1993 Nissan Skyline R32 GXi Type X
Engine: CA18I
Type: Inline 4 OHC
Capacity: 1809cc
Bore x Stroke: 83mm x 83.6mm
Kw: 67Kw
Torque: 142Nm @ 5200 RPM
Carburetor: --
Brakes: Vented discs (front) Drum (back)
Speed: --
Length: 4580mm
Width: 1695mm
Height: 1340mm
Weight: 1360kg
1993 - 1995 Nissan Skyline R33 GT-R
Engine: RB26DETT
Type: Water-cooled inline 6 DOHC 24 valve IC Twin Turbo
Capacity: 2568cc
Bore x Stroke: 86mm x 73.7mm
Kw: 206Kw
Torque: 353Nm @ 4400 RPM
Carburetor: --
Transmission: 5MT FULL4WD
Speed: --
Length: 4545mm
Width: 1755mm
Height: 1340mm
Weight: 1480kg
1993 - 1995 Nissan Skyline R33 GT-R V-Specification
Engine: RB26DETT
Capacity: 2568cc
Kw: 206Kw
Carburetor: --
Speed: --
Length: 4545mm
Width: 1755mm
Height: 1355mm
Weight: 1500kg
1993 - 1995 Nissan Skyline R33 GTS
Engine: RB20E
Type: Inline 6 OHC
Capacity: 1998cc
Kw: 96Kw
Torque: 172Nm @ 4400 RPM
Carburetor: --
Speed: --
Length: 4720mm
Width: 1720mm
Height: 1360mm
Weight: 1290kg
1993 - 1995 Nissan Skyline R33 GTS Type G
Engine: RB20E
Type: Inline 6 OHC
Capacity: 1998cc
Kw: 96Kw
Carburetor: --
Speed: --
Length: 4720mm
Width: 1720mm
Height: 1360mm
Weight: 1290kg
1993 - 1995 Nissan Skyline R33 GTS25
Engine: RB25E
Type: Inline 6 OHC 24 valve
Capacity: 2498cc
Kw: 140Kw
Torque: 230Nm @ 4400 RPM
Compression Ratio: 10.1:1
Carburetor: --
Transmission: 5AT FR
Brakes: Vented disc (front) disc (rear)
Speed: --
Length: 4640mm
Width: 1720mm
Height: 1340mm
Weight: 1340kg
1993 - 1995 Nissan Skyline R33 GTS25 Type S
Engine: RB25E
Capacity: 2498cc
Kw: 140Kw
Carburetor: --
Transmission: 5MT FR
Speed: --
Length: 4640mm
Width: 1720mm
Height: 1340mm
Weight: 1320kg
1993 - 1995 Nissan Skyline R33 GTS25t Type M
Engine: RB25DET
Type: Inline 6 OHC 24 valve IC Turbo
Capacity: 2498cc
Kw: 184Kw
Torque: 294Nm @ 4400 RPM
Compression Ratio: 9:1
Carburetor: --
Speed: --
Length: 4640mm
Width: 1720mm
Height: 1340mm
Weight: 1360kg
1993 - 1995 Nissan Skyline R33 GTS4
Engine: RB25DE
Capacity: 2498cc
Kw: 140Kw
Carburetor: --
Speed: --
Length: 4640mm
Width: 1720mm
Height: 1355mm
Weight: 1440kg
1996 Nissan Skyline R33 GTS Urban Runner
Engine: RB20E
Type: Inline 6 OHC
Capacity: 1998cc
Kw: 96Kw
Carburetor: --
Speed: --
Length: 4640mm
Width: 1720mm
Height: 1340mm
Weight: 1280kg
1996 Nissan Skyline R33 GTS Type S
Engine: RB20E
Type: Water Cooled Inline 6 OHC
Capacity: 1998cc
Kw: 96Kw
Carburetor: --
Speed: --
Length: 4640mm
Width: 1720mm
Height: 1340mm
Weight: 1280kg
1996 Nissan Skyline R33 GTS Type X
Engine: RB20E
Capacity: 1998cc
Kw: 96Kw
Carburetor: --
Speed: --
Length: 4720mm
Width: 1720mm
Height: 1360mm
Weight: 1300kg
1996 Nissan Skyline R33 GTS25 Type S
Engine: RB25DE
Type: Water Cooled Inline 6 DOHC 24 valve
Capacity: 2498cc
Kw: 147Kw
Carburetor: --
Speed: --
Length: 4640mm
Width: 1720mm
Height: 1340mm
Weight: 1340kg
1996 Nissan Skyline R33 GTS25t Type M Specification I
Engine: RB25DET
Type: Water Cooled Inline 6 DOHC IC Turbo
Capacity: 2498cc
Kw: 184Kw
Carburetor: --
Speed: --
Length: 4640mm
Width: 1720mm
Height: 1340mm
Weight: 1370kg
1996 Nissan Skyline R33 GTS25t Type M Specification II
Engine: RB25DET
Capacity: 2498cc
Kw: 184Kw
Carburetor: --
Speed: --
Length: 4720mm
Width: 1720mm
Height: 1360mm
Weight: 1390kg
https://www.sau.com.au/forums/topic/52367-skyline-guys/#findComment-1035050
1998 Nissan Skyline R34 25GT
Engine: RB25DE
Capacity: 2498cc
Kw: 147Kw
Torque: 255Nm @ 4000 RPM
Carburetor: --
Speed: --
Length: 4580mm
Width: 1725mm
Height: 1340mm
Weight: 1340kg
1998 Nissan Skyline R34 GT FOUR
Engine: RB25DE
Capacity: 2498cc
Kw: 147Kw
Carburetor: --
Transmission: FULL 4WD 5MT FR
Speed: --
Length: 4580mm
Width: 1725mm
Height: 1340mm
Weight: 1450kg
1998 Nissan Skyline R34 GT-Turbo
Engine: RB25DET
Capacity: 2498cc
Kw: 206Kw
Torque: 343Nm @ 4000 RPM
Carburetor: --
Speed: --
Length: 4580mm
Width: 1725mm
Height: 1340mm
Weight: 1410kg
1998 Nissan Skyline R34 25GT-X
Engine: RB25DE
Capacity: 2498cc
Kw: 2147Kw
Carburetor: --
Speed: --
Length: 4705mm
Width: 1720mm
Height: 1375mm
Weight: 1400kg
1998 Nissan Skyline R34 GT-V
Engine: RB25DE
Capacity: 2498cc
Kw: 147Kw
Carburetor: --
Speed: --
Length: 4580mm
Width: 1725mm
Height: 1340mm
Weight: 1340kg
1999 Nissan Skyline R34 GT-R
Engine: RB26DETT
Type: Water Cooled Inline 6 DOHC IC Twin Turbo
Capacity: 2568cc
Kw: 206Kw
Torque: 392Nm @ 4000 RPM
Carburetor: --
Speed: --
Length: 4600mm
Width: 1785mm
Height: 1360mm
Weight: 1540kg
1999 - 2000 Nissan Skyline R34 GT-R Victory-Specification
Engine: RB26DETT
Capacity: 2568cc
Kw: 206Kw
Carburetor: --
Speed: --
Length: 4600mm
Width: 1785mm
Height: 1360mm
Weight: 1560kg
1999 - 2000 Nissan Skyline R34 GT-R Victory-Specification II
Engine: RB26DETT
Capacity: 2568cc
Kw: 206Kw
Torque: 392Nm @ 4400 RPM
Carburetor: --
Transmission: 6MT FULL4WD
Speed: --
Length: 4600mm
Width: 1785mm
Height: 1360mm
Weight: 1560kg
1999 Nissan Skyline R34 GT-R V-Specification N1
Engine: RB26DETT
Capacity: 2568cc
Kw: 206Kw
Carburetor: --
Speed: --
Length: 4600mm
Width: 1785mm
Height: 1360mm
Weight: 1550kg
https://www.sau.com.au/forums/topic/52367-skyline-guys/#findComment-1035051
Engine:            RB20E
Capacity:            2498cc
Kw:                132Kw
Carburetor:            --
Transmission:            5E-AT
Speed:                --
Length:            4530mm
Width:                1695mm
Height:                1325mm
Weight:            1360kg
That should be RB25DE not RB20E, and the R32 GTS25 Type S was released in August '91 and finished in July '93... sorry to split hairs.
https://www.sau.com.au/forums/topic/52367-skyline-guys/#findComment-1047002
The R32 GTS Type J is a RB20DE aswell.
Jason you should go back and check those specs you put up, theres quite a few mistakes. Thanks for going to the trouble though, top effort!
well, i just posted what i was gven a while ago, by someone....so if anyone knows of discrepancies please let me know, and i'll fix it..
thanks rezz
https://www.sau.com.au/forums/topic/52367-skyline-guys/#findComment-1047068
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
