had the stagea on the dyno with the 3076 .82 on.
everythn standard besides
exhaust 3 inch
fmic
pod
nistune
made a nice 240rwkw on 11psi.
cant wait for injectors pump and afm. im planing to run 17 to 18 psi and should make the 300 to 320kw mark. il let yas now how i go once i finish the mods.
How lean is it?
I am only getting a bit more on 15psi, 245-250rwkw
How lean is it?
i lookt at the afr and they seem fairly stable. i told the guy i got tuning it that its gonna take a beating so i want it safe. so hes done what he can with the standard injectors. il see if i can get a couple of print outs and post em up for ya. injectors are running 90% duty. i was shockt it made over 200kw with em.
  • 4 months later...
its pork hunt drifting here im on mates user name cause i cant remeber my pass.
i had rbpower on the dyno again after putting new coil packs in and upping boost from 12 to 14 lbs.
the cars now making 262rwkw with
garret 3076
3 inch custom zorst
pod
fmic
nistune
just put a z32 afm on this arvo and gona lift boost to 16psi if standard injectors let me. they only seem to be running 70 to 80% duty at moment. il update results if i get another tune on sat.
Had my car dynoed at Edge Motorworks by Cihan today...well its the 2nd time. Last week I had my LPG and Petrol tune. Today was E85/Flex fuel tune.
Mods - Note - "Custom" = Scotty's fabrication :worship:
Custom suction pipe
Custom dump/front pipe to Fujitsubo Legalis
Stage 1 hi flow @ 17(?) psi
HDI Intercooler
Blitz SUS Power air filter
Turbosmart boost controller
Greddy Emanage Ultimate
trans cooler
RVO Auto stage 2 shift kit (valve body upgrade/line pressure increased)
610 Deka injectors
Walbro GSS342
JTG Liquid Gas Injection system
Results:
98RON: 247awkw, ~800NM
LPG: 250awkw, ~850 NM
E85: 270 awkw, ~950NM
didn't get dyno sheets as printer not working!!
this is a "screenshot" from last week:
Pretty happy with the results...next step is looking at an EBC and modified actuator to hold boost
Very nice mate, and I am back to the stock turbo. >_<
Glad you like my old setup. How does it feel? :thumbsup:
That pic is terrible, I will see if I can get a print/photo of your 270kw run later today.
Its good!!! Its nuts when it hits 3k+ rpm
Yeah, see if u can get something. He would've saved it right? I dunno...Cihan was in a real hurry to leave...had issues getting my car OFF the dyno LOL...and those straps...I think you better make some miracles with those bits ur welding onto his dyno!
Custom suction pipe
HDI Intercooler
trans cooler
610 Deka injectors
Walbro GSS342
Results:
NICE!!!!......stick up the e85 run when you get it.....what boost? you'll like the modified actuator.....bit of a gain for yah....have you changed you plugs yet?
Edited by Jetwreck
Looking at the dyno graph, does anyone know what causes tha power dip at 3500rpm??
I have a stock M35 and can feel a very noticeable loss in power at 3500rpm, which is also in the dyno result above?
Also, what is the actuator mod mentioned above?
At a rough guess, I'd say it was the Torque Converter locking up in the Auto gearbox.
I think I've seen it mentioned in other dyno graphs by people with Autos, but I'm happy to be wrong if someone has a better explanation.
yeh what PN-Mad said.
The modified actuator is done but putting a bigger spring on the outside....sort of works like a preload.
Works good too, brings it all on heaps earlier, just like the grub screw in the BOV. :thumbsup:
I just got back from tuning after fitting the stock turbo, it was only a temporary tune as Garrett is out of GTX turbo's at the moment. Running ethanol and pushing 1.2 bar the stocker made 225awkw and 850nm. I might just stick with this one for a while... :cheers:
This is a good representation of what a stock turbo (17psi) and a stage 2 (20psi) can do on ethanol, overlaid on the same graph. Cihan was very impressed with the stockers capabilities.
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
