with the BC kit i've noticed there are 2 types
- BR type RS series....................... more expensive
- V1 design VS series................... less expensive
whats the better one to get???
BR's are what I have, very happy with them. Iain has the same.
Not sure if one is "better" than the other; I'd be willing to bet the damper cartridge is the same, just prettier collars on the BR's.
Edited by Daleo
what pic?
the ones on the justjap site dont look anything like the M35 ones. for a start, the rear of our car isnt a 'coil-over' type setup
yeh i just realised that again.
but if you compare them with the VS models the tops are different, so a wrong assumption by me.
looks like im just gonna get the VS's...
You don't try hard enough Iain! :nyaanyaa:
n00b question, but are there adjustable wishbones available?
Yes, but I doubt you'll need them. Camber is pretty good when you lower. I'd use offset bushes in the std arms, that way you still keep your ride quality.
Hey guys, Just into the coilover swap now.......S1 1997 RS4.
Couple of small questions, What's the difference between 34GTST and 33GTR front coilovers?
I know the spring rates are different as mentioned in this thread, but are the physical dimensions similiar?
And will a standard Stagea rear strut hat fit an a/m S14 rear coilover?
Thanks + Cheers :)
well 34 GTT (or 33GTST?) are rear wheel drive so id say different to your RS4 stagea. R33GTR physically fit. the s14 would physically fit an auto RS4 but top hats/mounts will need to be modified due to being too wide IMO. dampeners will be adjustable so you might get past the different valving in the shocks
if your buying coilovers why not just buy stagea specific coilovers?
Hey after searching and searching this thread and others, I'm still trying to find a definite coilover setup that will fit my rs4s I was looking at bc coilovers but I'm not sure now which ones I'll need Im pretty sure r33 gtr will go straight in but the valving is wrong will this make a huge difference if both the spring rate and damping is increased
Is your RS4 manual? AFAIK the manual's have the same shock bottom on the rear as a GTR (Fork-type), whereas Autos have GTST type shock mount (eyelet-type). My understanding of this thread is that R33 GTR front will be fine, but both R33 rears have wrong valving. Justjap list them specific for a Stagea with both Eyelet and Fork type rears.
Pretty easy to tell what you need if you poke your head under the back of the car and take a look at the bottom of the shock.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
