How wide are your rims? Excessively wide rims will not help your roadholding. I have 17 x 9 (with 255 40 17 tyres) and use 15mm spacers to clear the shocks and have pushed out the guards a little. My shocks are Bilsteins with Tein Springs which are about 20% harder than stock. My ride height is 340 front and 330 rear. You can use BC coilovers. If your rims are getting in the way of some good suspension change them. My rear sway bar is the BNR11XX 24mm. When I track my car I have 17 x 8.5in rims with slicks.
. Sorry! i can't edit my posts. My
I've read about 30+ pages and scoured the Internet for a few weeks and I can't find a definitive answer.
I don't think i can use aftermarket coilovers as i only have a cm of clearance from the stock shock to the rim and i have a cm of poke so i can't use spacers.
What lowered springs fit the standard stagea shocks?
I've read a few threads where people say that 33gtr front springs and 33gtst rear springs fit the standard stagea shocks. But from reading these posts it seems as though they're confusing springs with shocks with coilovers, as everyone has said the 33gtst rears have a larger top hat. So in theory the springs will not fit the standard stagea shock?
The stock stagea spring rates are Front - 2.9 & Rear - 3.1 Most aftermarket spring rates are in the mid 3's F&R So this should compensate for the heavier rear end?
Please i really need some help as information is scarce!
I would like to track the car, but it will probably never happen, most of my driving is at the posted 70kph with plenty of round abouts and sharp corners, I like the car to feel less boaty (rims made a huge difference), this is my reason for harder lower springs and sway bars. Just coilovers wont give as good of an upgrade, is this correct?
I've tried to give as much information as possible.
I've also emailed a few companies but have not received any replies.
My rims are 9.5" wide on the rear with 245/35/19.
I measured the clearance: 15mm rim to shock. 10mm shock collar to tyre. 5mm poke.
ride height: 400 front. 370 rear.
The handling from 19" rims was outstanding, coming from 225/50/16 & 205/55/16 with 32 & 36 & 38 & 40psi. I've tried a few combos ha. and would like to keep these rims.
I could use some 10mm spacers, but once BC's are lowered the spring would hit the tyre wouldn't it?
Do you know the code off your teins? Their website doesn't list any springs for the skyline or stagea.
Thank you again Bob you've been a big help with things!
I have Tein "S" tech
Front Tein F-SIN78-101311-HCC
Rear Tein R-SIN79-010382-HCC
Shocks are labelled "Nismo" but are actually made by Bilstein
Front Nismo 56110-RSC45 ENP
Rear Nismo 53210-RSC 45 ENP
If you have 245 tyres (narrower than mine!) you only need 8 or 8.5in rims - the extra width won't be helping but just get in the way.
This is a picture from adams rear tein coilovers. Judging from the shock length and cir clips, it should lower my stag 2-3" before the cir clip will touch the tyre. What do you think?
Yeah i know the rims are quite large form the rear, but they look amazing and i got them for a good price. I'm not willing to sell and buy new rims atm
LOL I'm an idiot, no way they're fitting in the rear.
Found a thread from '08 everyone agreed that
gtr33 springs fit the front & 33gtst springs fit the rear. I'm guessing the is for an rs4s?
Found another thread from the whiteline group buy
34gtr spring fit the front & 32gtr springs fit the rear. I'm guessing this is for an rs4 S1?
I don't like wasting money buying things and finding out they don't work.
Any help is greatly appreciated.
Mine where put together by EVO R in Perth they are std coilovers. From what I remb it was 32/33 gtr tops and lower for the front and s15 tops with 33 gtst lower for the rear. But not 100% on that.
Btw think u might beable to undo the lower part of the coilover to adjust the length
S15 tops with 33 bottoms for the rear?
Couldn't I use my stagea std tops on 33 rear bottoms?
Info from king springs and this thread:
Front:
Kdfl101sp - 380mm - 175lb - 3.125kg
Kdfl101 - 360mm - 1st Inch 135 inch pound, remaining 180 Inch Pound
Rear:
Kdrs87 - 360mm - 195lb - 3.48kg
Kdrl102 - lower than kdrs87 - 155lb
Kdfl101sp & kdfl101 & kdrs87 has been used buy an awd stagea owner/customer of kings, and these are the measurements taken.
I have bought a brand new 24mm rear swaybar kit and a 22mm front swaybar for very cheap.
This should stop any camber/shock rubbing issues with hard cornering. Eventually I will get a stock front stagea strut brace to use in the rear.
Kdfl101sp and kdrs87 are the springs I will be using. Unsure how it will handle with .32 harder springs in the rear as most people use softer rears.
Is there anything anyone would like to add? Or disagree with?
King springs are usually $120-150 to your door for a set. Cusco $140 from jap unsure on shipping probs $300 all up, stagea front $60-$100 to your door, and it matches the front with the sticker ha.
Do you know if I could use my std tops on 33 bottoms? I've never seen either of them out of the car, I can't see why not?
Why don't you think I should bother with kings? I know you can get teins that are $330 to door and front - 4.2kg. Rear - 3.6kg. I think these would be a lil stiff for the standard shocks and would bounce a lot. What do you think?
How low was your vl? What's shocks were used? What condition? What were the spring rates? What other mods did you have?
A friend had a vs with ssl with shortened Monroe gas all brand new and it was bouncy and would thump on large bumps. While I had an ef with 2" lowered lovells with shortened kyb shocks that were a package and that was very comfy yet firm and handled well. Bushes played a large roll in this, and rim/tyre size too.
I'm far from an expert in suspension, but I believe the shocks need to match the springs for a good yet comfy ride. That's why I'm leaning towards kings as they're 0.2 heavier in the front and 0.7 heavier in the rear.
The stagea is 200kg heavier than a 33gtst. And that's not 200kg of weight in just the rear, that would be in the front suspension/diff, electric seats, gearbox, rear glass, sound deadening. I would say the stagea is only 50-100kg heavier in the rear than a 33gtst as a 33gtr is 100kg heavier than a 33gtst.
This is why I think 33gtst shocks will work fine in the rear. It's like having a family or car pooling. I do neither.
Does anyone here had experience with Jamex Super Lows Springs? I read alot of conflicting reviews about them. Are they any good? or just waste of money.
I remember reading something about them (perhaps in this thread somewhere), but i would also like to know other opinions..
Got it all sorted now, i got recommended to see the guys at Light Suspention and wheel alignment. Only cost $90.
10kg springs in the front with -1 degree camber, 8kg springs in the rear with -1 degree camber.
The car now drives like a dream, it just needs bigger sway bars and it'll be sweet.
Does anyone know the part number for M35 stagea front lower ball joint?
I've brought a set from here: http://www.ebay.com.au/itm/250697175942?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649#ht_827wt_1163
put it in and there is lots of movement after the install. I've notice that the ball joint i've got is missing a "cap" that the original have on top of the rubber.
Any suggestion?
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
