Nope wasn't me, theres another silver stagea around my area, i've seen it in newcastle, it's got chrome 18's from wat i can tell and looks like it might be lowered.
Mines got R32 style 17's on it :(
Mines got R32 style 17's on it :starwars:
AH ok, i just assumed since it was silver and in this area. they turned around and followed me for a bit, but never pulled over to say g'day
Green stagea,
with numberplates STAGEA
keep seeing it around penrith.. damn its nice.
i want one. although i have a feeling theres less c210 coupe's on the road out here now than stagea's B)
Saw a silver rs4 on loganlee rd this afternoon.
I _think_ he lives around the same area I do, he has ajm motorsport sticker on the back.
Ernie from Nizmo Imports lives just off Loganlea Rd and he usually has 4 - 6 stageas or V35's in his back yard. So it could be him.
i've been in Newcastle quite a few times, down by the waterfront on a friday/saturday night. you're right though, i never see any other stageas there.
I've been at summernats all weekend too, no Stagea's there either.
that would be mine. :(
i am the manager of the supercheap store there. yes i know my avatar is not that car but it is what my car should look like in 12 months.
awesome... yeah we stopped at the supercheap on the way from Melbourne to the Gold Coast. We picked up some windscreen wipers and a $150 sony cd player (I had removed the one in the car, and we cbf driving the rest of the way in silence). Pulled into the driveway and one of the guys in the car yelled "oh my god, its a stagea in the middle of nowhere!". We also chatted up your checkout chick, but we didn't get any phone numbers or discounts :P
hey yeah that would have been me that served you and got u that cd player. if u would have mentioned who u were i could have given u a discount, and u were chatting up the wrong checkout chick if u wanted a phone no. so if on the off chance that u drive through Taree again call in
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
