spotted a silver series 1 on rockingham road today just before yangebup rd wish I knew who it was I see them all the time maybe they will stop when I get the stagea on the road and they see the twin of their car coming towards them :wave:
spotto'd a series1 heading toward melbourne on western freeway just before melton.
was a silver one only saw it at the last second and not sure if he spotto'd me in my yellow S2.
must say it was nice to see another one on the road as its the first time i have seen one goin the other way.
saw a white series 2 in hassall grove was following it and realised it was the dragon wagon lol made room in the drive for her too :)
:O:( HEY, YOU CAN'T USE THAT TERM, MIKE!!!
MINE is the DragonWagon!
*shakes fist* :spank::rant::):O:mad:
Oh, alright - you can use it. I should have copyrighted the name as soon as I thought of it, though... :D:)
lmao its ok u can have it she was pissed as when i called it that. :)
Spotted a silver series 1 10 km east of Wellington on Friday, had a front bar on it, was driving a ute from work, (silver Hilux, no tray) looked at it coming struggled to comprehend seeing one in the middle of no where.
I truly had FOUR sightings in Southport today. A Beeeeutiful Blue S2 with an import place sticker on the back window. I've seen it before and saw it twice in different parking spots outside Southport Hospital.
The silver S1 I saw parked in Southport and then at the roundabout at Nerang
IFS. Had a ding in the back bar.
last nite spotted a mint maroon stagea on belvedere drive in montrose.
nice wheels, fmic.,
i want one!
nice looking car
Hooray i was spotted!
Also spotted Fuzz on tuesday (well your car anyway) Parked in the city dont know what road it was on as i dont know the city that well but all i know is its kinda near albert park lake.
spotted a silver S1 cnr Bradman Blvd / West Tce on 10th Oct at 4.30pm.
looked nice & different sitting in traffic, gave a wave from opposite side of the road in my S1
funny that, cant really do it if you were a VT driver to another VT driver....... hehehe
Finally l'm spotted too!!!
Though car was prolly filthy when u saw it .. in desperate need of a wash!!
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
