iamhe, you drove right by my place and didnt call in for coffee? Werent you going to drop off that Emanage ultimate too? :rofl:
I may... for a price.
Had my wife with me and we both had to go back to work, so no coffee.
Maybe some other time, bud?
Spotted Scotty NM35's Stag... in his driveway.
Nice car bud, Love the FMIC setup & throttle body pipe (but you knew that already) f*ck'n loud exhaust though!
(You would love the exhaust Iain/Craig!)
Edited by iamhe77
lol...gayness calls coming from the gay silver poverty pack twins.....one of them undergoing botox on there headlights and other parts!!!
what is it again Ian????...."When I get gay, I stop being gay and be an awesome homo instead. True story!"
P.S. If I was going to turn it would not be for a male 6ft3" Clayton's Volvo driving mad scientist....Ian's much cuter because his small!!!
P.S.S. There, I have insulted three people in one responce!!!...and I wonder why people think I have an attitude problem!!!! :)
Edited by Jetwreck
and it goes P.S. then P.P.S for post post script dumbass
like I said gay!!!!
Maybe I should I record this day of the month in my diary for Mr Happy!!! :) you've had a go at everyone today!!!!
.....been pissing myself laughing at some of the responses you've given today to overnight experts!
geezus, remember OUR conversation about the exact same topic? lol
anyway, ill concede defeat on that subject with them. but ill be wasting my money on that non-mod in the coming months
Will tell you one thing...I have done 2 throttle bodies....one on a VR HSV 215i(change to Duel Plenum...big improvement in throttle response but car was NA)....and one on a Turbo XR6(not a big improvement but definitely noticeable).
:P:D:(:laugh: Silver? :huh:
Bit sensitive there Craig?
Perhaps there is more to this than a quiet joke!
btw, your display of jealousy of my to-be headlights is quite obvious, Mr. Pokemon lover :P
Edited by iamhe77
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
