your car looked awesome... i pulled up along side of u to say hi and then i couldnt be bothered, was so tired. pulled the trailer from the other side of lithgow all the way up to erina ( past gosford) got home at 3.30am! one of the slowest trips i had up the freeway!
lol thanks.. long drive eh!! far out..
today i spotted a red RS4 S cantebury rd, the driver slowed down and gave the thumbs up.. gave one back..actually was on my way back from test driving M35's lol Read post in topics.
Spotted red series 1 with "574GEA" plates yesterday. Heading up the coast from brissy. I turned off at the redcliff/northleakes turn off they kept going. We both exchanged friendly waves. I love the excitement that comes with seeing another stagea :sick:.
omg i spotted 3 white stageas.
firday night on the big road that goes from the airport to phillip island, a white one WGNC34
and then 2 white stagea tow cars at the track over the weekend. good work guys :banana:
Spotted Andy's car in the carpark of one of the locals tonight, woulda come found ya but
the line was too massive and i was hungry!
I was quite tripped out at first as i drove in and saw a white stagea staring me in the face!
lol, spewin you ur car wasnt still there when i came out,
I was there for dinner with family for my brothers 19th b'day,
that line up was pretty full on but the food was incredible!
Yeh it is good food and cheap too, but i wasnt going to wait that long for
it...ended up going back to Rivo bowling club for dinner and won a meat
tray hahaha!
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
