Spotted!
Pearl white autech yesterday morning corner of Centre Dandenong and Warrigal Roads...
I was in the van, hot looking car...
haha that would have been me :D i have seen probably 4 stags in the last 2 weeks. Even 1 Blue M35.. things are becoming common! haha
Light blue or dark blue M35?
Where?
Edited by iamhe77
Spotted a White S1 Autech 260RS on Wurundjeri Way heading towards filders street. If your on here nice looking car mate, i drove past on the opposite side of the road in my Silver S1 RS-Four V.
hmm this coulda been me 2... i was in the area at that time. 2 spottos in a couple of weeks... didn't realise the car was that loud hehe i know its loud inside :D
hmm this coulda been me 2... i was in the area at that time. 2 spottos in a couple of weeks... didn't realise the car was that loud hehe i know its loud inside :P
I was to busy staring and was gonna beep the horn to get your attention but it was to late :D...
Spotted a whole heap of M35's at the Stagea meet tonight.
Thanks for the venue Jetwreck.
Spotted a light metalic green C34 on the wa home heading wes on Victoria road through West Ryde. Number plate UFO ___
you didnt mention spotting a blue fiat 500. i feel a bit left out!
nah i didnt, mostly because i had the best handling car there. ohh and most fuel efficient. and i could beat craig on a take off too :P
Are you telling me that your Fiat is faster than a Mazda 121....... Wow.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
