Spotted!
Pearl white autech yesterday morning corner of Centre Dandenong and Warrigal Roads...
I was in the van, hot looking car...
haha that would have been me :D i have seen probably 4 stags in the last 2 weeks. Even 1 Blue M35.. things are becoming common! haha
Light blue or dark blue M35?
Where?
Edited by iamhe77
Spotted a White S1 Autech 260RS on Wurundjeri Way heading towards filders street. If your on here nice looking car mate, i drove past on the opposite side of the road in my Silver S1 RS-Four V.
hmm this coulda been me 2... i was in the area at that time. 2 spottos in a couple of weeks... didn't realise the car was that loud hehe i know its loud inside :D
hmm this coulda been me 2... i was in the area at that time. 2 spottos in a couple of weeks... didn't realise the car was that loud hehe i know its loud inside :P
I was to busy staring and was gonna beep the horn to get your attention but it was to late :D...
Spotted a whole heap of M35's at the Stagea meet tonight.
Thanks for the venue Jetwreck.
Spotted a light metalic green C34 on the wa home heading wes on Victoria road through West Ryde. Number plate UFO ___
you didnt mention spotting a blue fiat 500. i feel a bit left out!
nah i didnt, mostly because i had the best handling car there. ohh and most fuel efficient. and i could beat craig on a take off too :P
Are you telling me that your Fiat is faster than a Mazda 121....... Wow.
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
