spotted a white M35 ARX on lyons road tonight. i beeped as theyed into a driveway. i think they saw me
forgot to mention.....spotted Ian's M35 in his driveway on the way to work on Sunday at about 7.30AM. This time I could not be bothered trying to wake him up....lol
i worked the night before too so i would have been dead to the world!
Spotted today around 8.15am in Brisbane near the Marriott (Elizabeth st?): Black S2 with heaps of dish on the rear wheels (RSV maybe?). I was sitting at a cafe, but the driver would have driven past my V35 parked pretty much in front of the Marriott...
Spotted Alex's stagea (CL11QE) parked on the main street of Richmond earlier today whilst I was driving around.
hey lol didnt even notice ur spot of me! me and the missus normally goto
a cafe there for sunday brunch - berry pancakes with icecream and
cream FTW!
cream FTW!
ooooh yumm, have to make a note to try them next time I'm out that way.
I was going to honk on the way past the second time but your windows were up and i wasn't sure how close by you were to the car.
Haven't seen mine in over 3 weeks - hoping it will be ready today.
Spotted a white S1 (I think) 260RS on Mt Tamborine on Sunday, around lunch time: not sure if the owner is on here.
Looked for either of Hugh's while I was up there, but to no avail.
You wont see the RS Four yet. Still waiting for the mech to do CV boots. 25G is usually at the Gallery between 10 and 4.
Oh, I forgot to mention I saw a glimpse of a white C34 heading West on Parramatta Road last Sunday - it was around 5.45PM, but I can't even remember what suburb I saw it in. I think it was between Strathfield and Leichhardt, but not sure. I was a passenger in my cousin's car heading into Enmore.
Spotted Nick (GoldZilla) last night at the Berowa Truckstop. Nice to meet you. Your car is very tidy. I will bring my Stagea next time for sure.
Spotted Andrew (02stagea) last night at the Berowa Truckstop in his Mini - and for the fact it's a Mini I understand why you brought it along.
What happened to you? I assumed you were coming up the coast, I would have liked to have had another look at the car in better light.
Fair enough - the last thing you want is for it to break down so far from home!
Then again, I could have folded my rear seats down (if necessary) and you could have wheeled the mini into the back of my car! :) LOL
spotted DVLASH ? or something similar black 260rs :blink: we had a bit of an on road chat at the lights of princess hwy and warrigal rd!! very wet night to be on the roads
it was about 11:30 pm
Edited by atomaly
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
