Spotted today: S2 grey, with big rims, on Smith St, eastbound at around 4pm. Car has black personalised plates with gold text: not sure if the owner is on here, but if you are: I was in the blue V35 pretty much next to you at the lights...
Spotted a red C34 in Blacktown about 30 minutes ago, first time I have seen a red one in the flesh, very nice!
We honked and went on our way.
Are you serious? That's the first red C34 you've seen?
StageIan owns one, s2, and he lives 2mins from me, meaning roughly 10mins from you...
Serious, seen every other colour imaginable but not the red!
It may have been StageIan, whoever it was I think they drove up to Lynwood Public or in that general direction.
I'm sure there are not heaps of reds one's about.
Pfft, stupid me - I was wondering all day "who owns that silver s1, why did they park all the way over there, and why didn't they come and say hello to us, the snobs?"
And the whole time, I didn't realise it was sh@un's car. Meh... :P
The other black s2 was technostormer, and the yellow s2 Duncan forgot to mention was MasterJDoggySomethingSomething :mad:
Oh I also saw at least another 4 scattered around the various parking lots, including what I'm pretty sure was Hugh's son's green s1 25G (now there are triplet dark green s1's :D) and a white s2 as I was leaving.
Spotted silver M35 with queensland rego on church street in Paramatta today. No badges on the rear. Long way from home :D
That was me. Moved down 6 months ago and keeping it registered in QLD till I can be bothered fixing my rear seat belts and converting it over. We were over the road at that annoying factory thing getting shoes :)
saw farking heaps of stags on the hill at superlap today!
the black s2 (sorry forgot your name!)
woop :D
good having a chat with some stagea owners finally.
saw a green s1 l plater on the way out too
Edited by teknostorma
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
