Ah nice. We stayed on Lorne on Saturday, and then drove the scenic section of the GOR Sunday - was a stunning day for it, albeit windy. Monday was a nice day for driving also, an excellent trip over all :/
was going to toot you on the westgate, but a 40kph zone, and me being in a SSS doubt you would've got the idea, sold me stagea about 3months ago now i think.
need my SAU stickers on the SSS, got a pedobear on the back window though haha
Nah havent got that done yet. Im having electrical issues just trying to get them cleared up.
Seem to spot a black c34 on seaford rd at 7.30 most mornings any one on here?
isnt me, but i have a black C34 on seaford road every weeknight on a tuesday for band practice :thumbsup:
I think the numberplate says something like 'devilish' cept shorter.
yeah i know the one :blink: we had a run in one rainy night on the princes :D nice guy!
DEVLAS ? or something like that ..... 260RS i beleive!
Saw a blue M35 with G***** gold on black plates in Help St Chatswood yesterday around 13:15. It had twin sunroofs and gold coloured brake calipers. I had just left #12 Help St and was talking on the phone so couldn't stop to chat. There was a woman in the passenger seat but no driver. They turned around about 5 minutes later and were seen going towards Anderson St. By chance are they a member?
sure sounds like bbenny.
Yep that was me! and my mum in the car! haha
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
