I came across this website yesterday, surprised to see that Stagea's are so well supported. I've been using a 1997 RS Four as a site car in Micronesia for the last couple if years and given it quite a lot of stick, need to keep it going for another year to see this project through. Suppose you could add this to the spotted list
There were 12 , including the uber cool bastard that just drove past and did not stop - like your style - sunday 24th oct 2010 , since being ousted from the GTROC UK ! the stagers owners club have been positive in there coming together and surviving quite nicely . more shots here http://www.facebook.com/home.php?#!/al...p;id=1311100133
Second time I have seen him.. I have to ask though it's looks way lower then mine and I struggle so much with bottoming out on speeds bumps, carparks etc. Does yours scrape alot??
Its not too bad. A bit of angle gets me over most things untouched. I originally had it about 2cm lower than it currently is and it was a nightmare, but seems perfect now.
I'm disappointed that I DIDN'T see a Stagea up for the challenge against the Merc AMG SLS, the Porsche 997 911 turbo and Audi R8 v10 - I think it would have kicked some butt!!!!! :P:D
I tried a few times.. but was disappointed.. :down:
^^ might come next week!! When and where??
Spotted spoolin this morning on my way to work in frenchs forest
http://www.skylinesaustralia.com/forums/ca...&hl=Coastie
Every Thursday night (I'm there almost every week, but sometimes I head up early so I don't stop at Berowra because there''d be no-one there).
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
