Spotted today around 10am: Stock looking grey S2 parked opposite Maccas at Robina, on Scottsdale(?) drive, pointing toward the auto mall....
That was me Micah, I was having brekkie at the Scottish restaurant before getting all my crap out of my parent's garage before moving next year. I have way too much stuff :lol:
Ah, I suspected it may have been you! Next time give a call if you're in the neighborhood: I only live about 3 mins away :P
was scratching my head over your post: I only just got the Scottish restaurant reference: getting slower in my old age! lol!
Wait till you get to my age. CRAFT.LOL
Just spotted a really dark green s2 C34 with stickers all over the back window on Station Road in Seven Hills, rego was RS45TR. I just did a run to the shops and was using the old man's car, should've taken my own... Bah!
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
