saw a black series 2 in the car park at Colonnades yesterday. My mum goes, "That looks like the same car you have, but yours is prettier. Black is just too dark, why do people buy black cars? It must get so hot in there.." lol
Damn, where was your mum when I was buying my boiling arse hot black Stag...
Well turns out I didn't need a cruise to have an import-a-rific night.
Day on on GT5, finally got my pearl white RSfour.
Back to the real world:
Off to a mates place tonight/last night. See a black S2 Autech on Grattan street (plates DVLISH I think, sweet looking car). Another white S2 on Maroondah hwy, exchanged waves. Then get to a mates place, he has a Green C34.
Then...
2 c34's going down mahroondah highway aroun 1130 tonight/last night :P
...Spot and get spotted by WGNPWR during the drive home. Then finally have a couple of "excited departures" from the lights, with a very nice R32 on Alexandra Pde.
4 Stags not including mine, not bad for a quiet night out :thumbsup:
PS, WGNPWR, your car looks tuff!
Guy I work with reckoned he saw a red m35 doing a runner from the cops on the f3 around Ourimbah last Thursday.
Said it blew past him doing 170km/h with a HWP following 30 sec behind.
So much for our much prized anonymity... Go buy a Commodore Sportswagon you peanut.
Hopefully it was just miss-spotted, and it actually a volvo :P
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
