That's me. Didn't see any other Stagea's though. Were you driving yours? I think this is the second time you have spotted me. Are you local?
yep live in south croydon
first time i saw you mum was driving me around because i couldnt drive >_>
this time you were turning into canterberry road of baysie road, i was in the turning lane going off canterberry into baysie road, you passed within about 3m of me :P
Dale,
That'll probably be the one from JapLink I mentioned a few weeks back. I dropped into Japlink on 6th Feb and spoke with Adam. He mentioned there was another one coming our way. He thinks they live in Springwood, NSW.
Rosella.
Mmm, interesting, will have to keep an eye out.
i work on spencer although i was on King street going home... lol
finally i may have been spotted!
Oh nice close to me
I work on king and park at flagstaff carpark then go down latrobe and right on spencer to get on citylink
:teehee:
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
