Trick is to book it direct and not through a coupon type website (ie, redballoon). Unfortunately we made that mistake an found out on the day that I would have had a longer flight and paid less if i booked it directly through the company. Company we did it with was Professional Helicopter Se
That's who I had my 1 hour trial lession with.... 43 minutes of "stick" time for about $320... Also used a Schweizer 300 with proper controls and not some R22 Y yoke thing...
Need to do it again soon...
That was me :action-smiley-069:. Sorry didn't spot you back. :whistling: Would have been on my way to or back from Moorabin airport for my Trial Helicopter Flight (ps, anyone whose thinking about doing it, DO IT, amazing experience).
Hmm funny, my wife's uncle took me up for a flight in his chopper a few months back. Along the coast down to Mornington. Was ok but got a bit meh towardss to end.
I'm sure flying it 1st hand makes a huge difference. I know I enjoyed my stick time in a cessna when I was younger....
spotted white s2 with black rims today at the JDM meeting, only me n him were the only stageas there.
but lots of other fun cars
That was me. Did a few laps of the place and kept coming back to yours to say hi, but never anyone near it when I went past.
i saw you right at the end when i left, i was the guy with the mario cap on, went to yours as well, but i had no clue who was there either. haha, guess when i was at yours you were at mine :P
Silver series 1 in a driveway high street bendigo on the way home from gtm :)
i also saw a white\silver s2 i think (it was dark and i was going pretty fast) heading towards bendigo on the way home from gtm.
and another white s2 on stkilda st heading towards city on fri about 7pm. i was in my blue s1
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
