Freddy where were you? My daughter was there for soccer training as well....Didn't see your car in the carpark??
I tried to park closer to you but the parking was full so i parked closer to the entrance at the other side( I guessed it was you 'cause you show your plates in another tread)
my kid is playing with the under 11's so see you around just look for the silver S2...
Well, I'm in Okinawa, Japan for work. Lots of good car spotting over here, even though I'm not on the mainland.
So far seen about 4 C34's and only one M35. Loads of other stuff. Old S13's and skylines of every model around. Not many turbo's though.
Will attempt to spot more Stageas!:thumbsup:
My advice: When you come back leave all your clothes and stuff there just pack your suitcases fully of stagea goodness!!:thumbsup:
+1 on that....do you want me to send you a list of what to bring back for me!!!
Spotted an M35 Axis outside of Belrose Supa Centre with a trailer advertising a carwash.
Also had a silver(i think, it was dark) C34 following me from Hale St in Botany to Brighton St, Gave a wave, clean looking car!
MaR1LyN
That was me following you from hale st in Botany, i live on William st mate, mine is silver, i like your car too mate, gave you a beep as you turned off stephen rd, pull over next time we spot each other, well have a chat.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
