Freddy where were you? My daughter was there for soccer training as well....Didn't see your car in the carpark??
I tried to park closer to you but the parking was full so i parked closer to the entrance at the other side( I guessed it was you 'cause you show your plates in another tread)
my kid is playing with the under 11's so see you around just look for the silver S2...
Well, I'm in Okinawa, Japan for work. Lots of good car spotting over here, even though I'm not on the mainland.
So far seen about 4 C34's and only one M35. Loads of other stuff. Old S13's and skylines of every model around. Not many turbo's though.
Will attempt to spot more Stageas!:thumbsup:
My advice: When you come back leave all your clothes and stuff there just pack your suitcases fully of stagea goodness!!:thumbsup:
+1 on that....do you want me to send you a list of what to bring back for me!!!
Spotted an M35 Axis outside of Belrose Supa Centre with a trailer advertising a carwash.
Also had a silver(i think, it was dark) C34 following me from Hale St in Botany to Brighton St, Gave a wave, clean looking car!
MaR1LyN
That was me following you from hale st in Botany, i live on William st mate, mine is silver, i like your car too mate, gave you a beep as you turned off stephen rd, pull over next time we spot each other, well have a chat.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
