Friday night I saw a white M35 on Parramatta Road somewhere between Five Dock and Ashfield (can't remember exactly where and what time).
I saw a white s2 C34 parked on the nature strip out in front of a house in Penrith last night too.
Spotted on Saturday morning a green series one on king st at Mascot, i was driving in front in the white holden combo work van, it sux because nearly every time i see a stagea i am not driving my own car pinch.gif
Hi guyes my name is adam i live at top ryde i have a c34 rs4 white rego bcq60e and my mechanic boss tuning working out of carline gladesville has a silver c34 rs4 rego fossil with r34 gtr rims who else lives in ryde with stageas ??
i drive passt that silver C34 all the time. isnt he an auto electrician or something?
Does that mean he can work with the hks f-con stuff?
i can ask him or call him paul 0424150997
he is at 25 higgenbotham rd gladesville (in carline mufflers)
he is organising the nistune for my car and his own car he should be able to do any computer just ask
Tangent - I think I have seen your car before near blacktown (i'm pretty crap geographically in the west, so it could have been anywhere really)
Looked awesome though with BNR34 front..
SPOTTED a black s2, RS4 C34 today at hornsby, some awesome skin on the boot (like sell me it?) and an awesome Mala sticker on the back window!! One day soon I will have the white equivalent with window art not just from the labs...
Spotted a blue/green custom colour Stegea with R34 GTR front end conversion and gold Volk GT-C at M on Mary Apartments secure car park in Brisbane (QLD) at 3:30pm on Monday (06-06-11).
I am in Brisbane for a week. Would love to see that car close up if the owner is on here. 
Edited by VNS 24
That could be Darrin. Check out his pic on 1st post here http://www.skylinesaustralia.com/forums/topic/363028-queensland-stagea-crusie-and-dyno-day-july-2011/ & see if that's the car.
Thanks, will not be panda spec by the end of next week though...
