spotted, pulled up and had a chat with a bloke in silver RS4S at townsville strand bout 7pm today, just moved up here apparently, looked like a nice example. and both of our missus' said they same thing hey look another one :thumbsup:
im on my way up to sydney tonight for a couple of weeks, keep an eye out for me haha. s2 sliver C34 - plates QIKNLO - will be all over the joint visiting mates and might hit up panthers maccas at penoo on a thursday night for ol times sake ahha.
nice work dude!
linky?
http://j-spec.com.au...EA-1647915.html
One owner
Front and rear cameras
Factory navi
Intelligent key & Immobiliser
Xenon headlights
Twin sunroof
Power front seats (no leather... yet)
AWD
Front and rear spoilers
Cruise control (looks like the same one Leon was doing)
Possibly aftermarket intake (need engine bay pic to confirm)
Cold pack
LSD
lol, 'sif I was going to be without buying a Stagea for long.
Nice work Cam!
Its a little bit earlier than mine, looking at the VIN. Looks like the Nismo Axle back exhaust,
Front cameras! lol, knew the V35s had em, didn't think the stageas did. Maybe they'll spot the Roo's jumping out at ya!
Edited by PN-Mad
Hey Josie,
Its me!
I'm pretty sure I've only beeped once but the flutter is a HKS SSQBOV.
Rice to meet you.
I want your spoiler... haha! Every time you go past I always think to chase you down haha....
I might just wrap my spoiler and be lazy.
Should stop by one time and say hi.. I'm the one with the brindle bullmastiff at the park... Plus I have a huge Domo sticker on my car now that you won't miss :P
Nice work Cam!
Yeah, Nismo or Autech was my first thought, but wasn't sure.
Already got a set of Tomei rods comin' whistling.gif... although not sure if going turbo or high comp NA
Car is in fantastic condition (Krist reckons it is "as nice as you'll ever buy an M35") although it does have a fully-hektic Blitz pod on it.
Pretty happy :)
Pretty happy :)
Very nice mate
Spotted a blue Stagea which happened to be Zeke on seacombe rd yesterday got the thumps up and he got the horn coz I was busy turning the corner and changing gears lol
Haha tripped out ..turned to look right and bam Stag.. Was so half asleep lol
Staggy looked very clean !!
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
