Silver C34 on Talavera Rd in Macquarie Park, about 30 seconds ago. Looking out the window at work.
Careful, the police have hitting this area really hard lately because it's a 50km/h zone.:whistling:
spotted a Black M35 on Bronze wheels (possible TE37's) crossing grand junction rd from bridge rd onto hampstead rd around 1.30pm, then a white S1 on main north rd turn right with u onto there, nd then u held me up because the falcon slowed down as u did to change lanes about 5-10 min later. nd wat looked to have been the same M35 or a similar one driving on hampstead rd heading towards grand junction rd again around 2.20pm.
Black M35 at Davoren Park On The Run this morning. Black Volk copies on the rear, silver WedSports on the front.
Anyone on here?
That would be my partners car
There hanbai m2 dt 05rs on the rear ( the wheels drift techs copied)
And yup a full kenstyle kit,
Now sitting on 18x9+20 o1g wheels
With some new bc coilovers
lol yea i was taking the kids home. nd thanks. yea ill hopefully get it resprayed soon. get the door rust fixed at the same time. still unsure of wat colour to go. nd then fix up my fog light. only cleaned headlights a few days ago as well. they were yellow.
just spotted at around 1.45pm: yellow s2 with large rims at Mudgeeraba Village, turned up Somerset Drive. I was a few cars behind, and not in my stag, so didn't get the opportunity to acknowledge...
4 days in Canberra, Thu arvo to Mon morning, and not one sighting. :nyaanyaa:
Not impressed with the average speed cameras planned for Hindmarsh Drive, either side of Red Hill. Plans to bring them online in late Feb after lightning damaged them. Purely for revenue raising I say. Yeh, sure there are hoons racing up and over Red Hill but having to use your brake constantly down hill is ridiculous. Reading the local paper suggests a 2% tolerance at most due to some legislation change in 2006 for speed measurement. I guess if it's successful, then NSW won't be far behind. Already got on one on GWH east of Bathurst for trucks. :mad:
Spotted my car driving away for the last time......
Congrats Marty, I know you'll look after her!
I spotted it getting the last once over. Must have gone soon after. I should have dropped in and said goodbye to her!
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
