spotted very clean series 2 c34 stag,silver with body kit,parked opposite maccas in maroochydore tonight about 8.00pm.I was in blue m35 parked next to you but no onein your car,if you are on here,nice looking rig.
Spotted a White C34 on Talavera Rd in Macquarie Park this arvo, and literally as I'm writing this; I believe Bodalla just drove past (sounds niiice!) on Talavera heading towards Macquarie Centre.
I'm a freakin' Stagea spotting ninja this arvo!:banana:
Edited by Daleo
Spotted a few stageas at all Japan day today ;) was a
Great day out
Just trawling through some facebook photos, looks like it was a good day!
Looks like theres another Kenstyle kit in adelaide! And has nice wheels :worship:
http://www.facebook.com/photo.php?fbid=279800512091110&set=a.279794058758422.66410.100001834906826&type=3&theater
Spotted 2 stageas at classic Japan show yesterday, silver s1 and a white autech c34. Then after the event a dark red s1 pulled in. I was in a Suzuki mightyboy at the show, the supercharged one :) To the guy with the silver s1, that's a sweet lookin stag.
Got it just over a year ago , had wed 19" wheels and tein basic suspention,
Swapped over to some Bc br a month ago and popped on some 18x9 +20 option 1 garage wheels ,
Something different from
The chrome ,
It's fairly low now;) but had to
Lift it 10mm after yesterday , just
To be on the safe side
, no ather mods besides the usual stereo , front n Rear camera ,
The chrome ,
Not a lot a clearance at the front by the looks.....I'm hoping I have a little more or I may have to modify it more than I thought.
You'll find the front of the Kenstyle does sit a lot lower than stock suspension! Even with the arx springs spoon drains are my mortal enemy - and the little concrete bump stop things in carparks also need to be kept well clear of.
Well as it sits in that photo u can't fit ur finger under the front bar , even with force , sat about 1cm off the ground on the road ,
The ken style kits is a awesome kit in my eyes but not good for going low ,
So how many ppl run the kenstyle kit , I'm yet to see another
my front bar is 150mm off the ground and only just clears most of those concrete bump stop things in carparks, have some problems with driveways at times also LOL
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
