spotted very clean series 2 c34 stag,silver with body kit,parked opposite maccas in maroochydore tonight about 8.00pm.I was in blue m35 parked next to you but no onein your car,if you are on here,nice looking rig.
Spotted a White C34 on Talavera Rd in Macquarie Park this arvo, and literally as I'm writing this; I believe Bodalla just drove past (sounds niiice!) on Talavera heading towards Macquarie Centre.
I'm a freakin' Stagea spotting ninja this arvo!:banana:
Edited by Daleo
Spotted a few stageas at all Japan day today ;) was a
Great day out
Just trawling through some facebook photos, looks like it was a good day!
Looks like theres another Kenstyle kit in adelaide! And has nice wheels :worship:
http://www.facebook.com/photo.php?fbid=279800512091110&set=a.279794058758422.66410.100001834906826&type=3&theater
Spotted 2 stageas at classic Japan show yesterday, silver s1 and a white autech c34. Then after the event a dark red s1 pulled in. I was in a Suzuki mightyboy at the show, the supercharged one :) To the guy with the silver s1, that's a sweet lookin stag.
Got it just over a year ago , had wed 19" wheels and tein basic suspention,
Swapped over to some Bc br a month ago and popped on some 18x9 +20 option 1 garage wheels ,
Something different from
The chrome ,
It's fairly low now;) but had to
Lift it 10mm after yesterday , just
To be on the safe side
, no ather mods besides the usual stereo , front n Rear camera ,
The chrome ,
Not a lot a clearance at the front by the looks.....I'm hoping I have a little more or I may have to modify it more than I thought.
You'll find the front of the Kenstyle does sit a lot lower than stock suspension! Even with the arx springs spoon drains are my mortal enemy - and the little concrete bump stop things in carparks also need to be kept well clear of.
Well as it sits in that photo u can't fit ur finger under the front bar , even with force , sat about 1cm off the ground on the road ,
The ken style kits is a awesome kit in my eyes but not good for going low ,
So how many ppl run the kenstyle kit , I'm yet to see another
my front bar is 150mm off the ground and only just clears most of those concrete bump stop things in carparks, have some problems with driveways at times also LOL
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
