Spotted Theo's AXIS on the hoist at the Penriff choice A-one Stagea bro happy times workshop last night.
I hope he didn't put the suction pipe on because he will be pulling it back off for the actuator!!!!
nope its getting ceramic coated first :D
spotted you today Dale at 4pm on York Rd :P i was in the work BRICK lol
Lol, with mine; you can actually get the actuator out without removing it. ;)
Sneaky! Didn't even know; hope I wan't picking my nose... :woot:
Base coat is going on tonight, along with some parts for the Makinnen.
Turbo is off, exhaust housing is getting coated, new Meek performance dump, and X-force full system going on.
Full hard piping kit, and a Walbro going in tomorrow. In a month or so it's getting a Quaife front LSD, and going for a power fc tune.
power FC?
hmm interesting!
Possibly should clarify; the TME that I was referring to, sadly doesn't belong to me. It's a car in my mates workshop that is getting some love.
I wish it did; but fitting up a bunch of sexy bits to someone else's car is going to have to do for now.
Wasn't finished in time for me to see it run today unfortunately. It's going to be a hell of a thing though.
Spotted again a black C34 S2 Stagea with black mags on Yass Rd Queanbeyan NSW yesterday (15 Aug) at about 0830. SA plates - must be more than just visiting as I saw it in the same spot a few weeks ago.
saw the yellow rs4s aswell, passed on reservior rd, i gave a wave and revieved one back, i was in my silver c34 s2.
cheers.
Wow i got seen alot this trip. Ur S2 looks sweet. I wish mine wasnt so dirty. Also spotted the 2 white S2's, a white m35, a gold m35 and a silver m35. All in and around WTAC.
I think u had parked near mine on the Saturday at the start of the drifts till I left. Little higher up the hill nd a row or two closer to the final turn. Mine had all the stickers nf was 2nd in from the track
    • Pretty sure it is a common fault. I believe this is the only part you need, but don't quote me as I don't have a V36.  I also believe it is a bit of a pain to change and the device needs to be encoded to the car once it is replaced, so may need someone with the right tools. Buy Genuine Nissan 48700JF00D (48700-JF00D) Lock Set-Steering. Prices, fast shipping, photos, weight - Amayama
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
