Spotted Stageian on my way home from work in Eastwood yesterday arvo.
Gave you a wave, but didn't expect you to recognise me on my bike with my helmet on.
Nice..... I was eying off the bike in the mirror & moved over cause I thought you might be splitting lanes.
Sweet ride, wish I still had mine.
Thanks mate; spotted the move. You can tell when bike riders are driving cars. ;)
How are you getting on with your knee?
Had to see 2 more doctors to assess my condition, these were arranged by the insurance company. One of them told me my knee is fkd & I'll need another opp to cut the bone reset it & reconstruct the ligament again. :down:
Wow dude; really sorry to hear that.
I thought I had it bad when I was off work for nearly a year when I smashed up my arm; yours is a completely different level.
Yeah I have 2 birthdays now, my birthday & my second chance day.
In other news I spotted a silver S2 heading along Mona Vale Road this arvo on my way home bout 5:30
Came back from shopping to find a black series 2 park next to me at Noarlunga in the Spotlight/Harvey Norman/Pet Stock car park on Thursday night
Bit late but due to only just getting an account..
This was my black stag! :) only brought It a month ago!
Ur silver stag looke well good!
Spotted a few Stageas down at the SAU nationals over the 3 day event!
A White RS260 ACT plates at the track day on Friday at Wakefield.
3 C34s (Nick, Gavin, and another white RS4 S - sorry forgot your name :( ) and My M35 in the Show and shine today!
And a Silver M35 Axis parked in a rest area southbound on the outskirts of Sydney on the hume about 4:30 today.
The White Autech was mine!
