What's this??
Another canary stag in Adelaide! Is the owner on here? I want to find out what exhaust you fitted haha
Wow, lowering and the larger set of GTR wheels actually makes the car look physically smaller in that photo!
Spotted two silver m35s on Sat, one with what looked like a freeway dolphin kit at Holmsglen tafe VIC about 9:30am and the other traveling in the opposite direction to me on High St about 6:00pm I gave the driver a thumbs up and got one back!
What's this??
That's Mike (i reckon thats his name) he walks his dog there nearly every day.
What's this??
If its who I think It Is he goes to the dog park you're parked at with his German shepherd x akita. It used to be my stag, his yellow one and another yellow one parked there every night haha
living in north lakes, went out to mount nebo for a day trip... only bought the car on friday!
love it in the sticks though.. wish i could afford a house out there :(
where were you heading?
HAHA! the avatar is meant to headbang..
I'm house sitting my oldies at Clear Mountain while they're caravanning around. I was heading out to grab some beers for band practice - good thing about a house in the sticks, no noise restrictions!! Pity there were cars in front of you, that's a lovely straight for some punchin'...
Yeah, babies NEVER head bang when you want them too!! HA HA!!
is a good straight, but my luck, every time i drive through there, someone always ends up in front of me :whistling: dont know how that keeps happening :P
gotta love not having noise restriction problems, enjoy it while you can!
oh to be able to watch movies and enjoy the surround sound!
would be good to be able to drive around and enjoy the scenery!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
