What's this??
Another canary stag in Adelaide! Is the owner on here? I want to find out what exhaust you fitted haha
Wow, lowering and the larger set of GTR wheels actually makes the car look physically smaller in that photo!
Spotted two silver m35s on Sat, one with what looked like a freeway dolphin kit at Holmsglen tafe VIC about 9:30am and the other traveling in the opposite direction to me on High St about 6:00pm I gave the driver a thumbs up and got one back!
What's this??
That's Mike (i reckon thats his name) he walks his dog there nearly every day.
What's this??
If its who I think It Is he goes to the dog park you're parked at with his German shepherd x akita. It used to be my stag, his yellow one and another yellow one parked there every night haha
living in north lakes, went out to mount nebo for a day trip... only bought the car on friday!
love it in the sticks though.. wish i could afford a house out there :(
where were you heading?
HAHA! the avatar is meant to headbang..
I'm house sitting my oldies at Clear Mountain while they're caravanning around. I was heading out to grab some beers for band practice - good thing about a house in the sticks, no noise restrictions!! Pity there were cars in front of you, that's a lovely straight for some punchin'...
Yeah, babies NEVER head bang when you want them too!! HA HA!!
is a good straight, but my luck, every time i drive through there, someone always ends up in front of me :whistling: dont know how that keeps happening :P
gotta love not having noise restriction problems, enjoy it while you can!
oh to be able to watch movies and enjoy the surround sound!
would be good to be able to drive around and enjoy the scenery!
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
